Originally Posted by Johnny G
I have a 03 Ford trans star and the batteries need to be replaced. How do you get off the external battery on the passenger side underneath the bus? All I see is bolts to the frame, will the battery drop when I pull the last bolt? As you probably can tell I no nothing about motors and just bought this bus.
It overheated on the highway, cracked the radiator and now it won't start.
thanks for any help
I doubt that it will fall anywhere when taking bolts out. It should come on a tray to you as you pull it out.
You are in the wrong place if you don't know anything about motors. Why a bus of all things? You have some major repairs not knowing what is/was going on.
