Old 10-19-2019, 01:21 PM   #1
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
block heater off house batteries?
a block heater typically draws about 3 amps on 110v power - any reason I couldn't use house batteries through the inverter to run the block heater for an hour or two?
Old 10-19-2019, 02:13 PM   #2
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
As long as the house bank will handle the load it should be fine.
Ted
Old 10-19-2019, 02:18 PM   #3
will be 30A off 12V, very heavy load like over 10 fridges
Old 10-19-2019, 02:20 PM   #4
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
best I use my generator then
Old 10-19-2019, 02:48 PM   #5
Bush pilots drain their oil into a coffee can. When they're prepping for take-off they heat the oil over a stove and then return it to the crankcase...
Old 10-19-2019, 04:23 PM   #6
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
I've used a tiger torch before - flame directed through a tin chimney with a 90 degree bend to the bottom of the oil pan - temps were off the end of the thermometer and the dogs had chewed off the wire to the block heater - made it to the race on time - - lol
Old 10-20-2019, 03:09 AM   #7
I am glad you askedthis question. Our bus is equipped with a block heater and I was considering the same ... just in case we needed it.
Old 10-20-2019, 07:31 AM   #8
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
remember as stated above it will be about a 30 (not 3) amp draw on the batteries. also inverters use (lose)juice to convert it. i would prefer to heat my oil
mmoore6856 is offline   Reply With Quote
Old 10-20-2019, 08:36 AM   #9
bigskypc50's Avatar
Coachwork: AMTRAM
Chassis: INT
Rated Cap: Big Girl
3 amps on a block heater at 110v? I thought must I have seen are 1000W, mine is a factory installed job, and I am pretty sure it's 1500W.
Yes if you have a gen set to use, I would totally do that, unless you were in a emergency and your battery bank is all there was.
bigskypc50 is offline   Reply With Quote
Old 10-20-2019, 09:04 AM   #10
With a 1500W block heater, you would deplete a 100Ah bank to 50% in 25min.
Old 10-20-2019, 10:46 AM   #11
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
one way to warm the motor/oil in extreme temperature when off grid, would be to throw packing blankets over the motor and stick a propane powered catalytic heater under the bus - wouldn't be as efficient as a block heater, but it would get the job done in a pinch - I wouldn't need to buy one as I already have one for my small workshop
Old 10-29-2019, 06:03 PM   #12
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
We plugged the block heater into our 110v grid for 30 minutes a week or so ago. It drew 100amp (12v) and dropped our battery bank from 13v down to 12.7v over that time. We have 920ah of batteries so I don't think it made a big dent into it.
Dave
Old 10-29-2019, 07:14 PM   #13
Coachwork: Winnebago
Chassis: Ford F53
Engine: Ford Triton V-10
Rated Cap: currently 2
I'm a big fan of Wabesto type heaters. They can thaw an engine block or keep it warm enough to turn over without issue and draws a lot less electrical power to do it. Uses a little diesel fuel in the process so unless your fuel gels also shouldn't be left stranded.
Sehnsucht is offline   Reply With Quote
Old 10-29-2019, 07:32 PM   #14
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
I think that's the way I'm going to go - no worry about the bus being warm enough to be comfortable, and no separate block heater needed
Old 11-02-2019, 05:03 PM   #15
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Back in the day, I had a VW Vanagon which I put a little woodstove in to take up skiing. When I went to start it at the end of the day it became apparent those air cooled engines didn't like cold or altitude. I cranked up the woodstove and opened the engine hatch in back(under the bed). After a couple of hours, it fired up and I headed down and went shopping for a Ford van.
peakbus is offline   Reply With Quote
Old 11-02-2019, 06:03 PM   #16
Drove '61-67 veedubs skiing through the Alps for many years, in the 80's and 90's no problems.
Maybe the fact they were maintained by German-speaking mechanics made all the difference
But yes, a woodstove would've been a nice add-on
8-D
Old 11-03-2019, 01:33 AM   #17
Rock-N-Ruth's Avatar
Chassis: Amtrans
Engine: 444E
Rated Cap: 84 pas
I carry a 500W heat lamp on a flat stand that I can slide under the oil pan for the ocaisional -20 night when I don't want to idle but need it to start in the morning. About 45 minutes. Does the job as well or better than a static block heater. I run it off my solar system. I've got a pretty decent battery bank if its not yet sun up. Draws led that the coffee pot.
Rock-N-Ruth is offline   Reply With Quote
Old 11-03-2019, 06:54 AM   #18
Once you factor in inverter losses a small genny seems the best way to power a block heater. I had a installed a flat plate heat exchanger in my circuit which could heat hot water or reverse with use of a 12v circualtor (solar) could heat the engine when needed. Hot water came from a Bosh tankless (LP).
Mudhutwarrior is offline   Reply With Quote
Old 01-24-2021, 09:23 AM   #19
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Reviving a old thread.
My 2003 Ford 7.3 does not have a block heater and I would like to install one. I can get a 1000 watt or a 700 Watt. My first though was bigger is better, but then I thought of the house battery question which brought me to this thread.
700 Watts/120volt=5.8amps. Correct? If this block heater was powered by an inverter, would this not be viable for a short time? My battery bank will be 224 amp hours. This would old be used very occasionally when travelling if in extreme temps. Maybe I don't understand amp hours.
If is not wise, I'll go with the larger heater since it won't matter on the road.
Old 01-24-2021, 09:46 AM   #20
kazetsukai's Avatar
Chassis: International RE
Engine: International T444e
Rated Cap: 76
I'm going to assume your battery bank isn't 120 volts. It doesn't matter if the heater is 120V, if you want to measure the amperage draw on the batteries, you need to divide the wattage of the consumer by the battery voltage to get a rough estimate.
For a 12V bank, you will be drawing 5.8A from the inverter, but to satisfy 5.8A at 120V, the inverter will need to be drawing 58.3A (more in actuality, due to inefficiencies) from the battery bank. With a 24V bank, you'd be drawing 29.1A. A 48V bank would be drawing 14.6A, and so on. Add 3% to 12% for inefficiencies.
kazetsukai is offline   Reply With Quote
