Old 05-05-2018, 09:07 PM   #1
Blue Bird 1989
Good evening,
I did the dumbest mistake and crossed my battery cables when putting in my school bus batteries since it was sitting during montana winter. Smelled smoke and the wire going to bottom of my started melted. Spliced it to make sure it would still start. Started for 20 seconds then died. Could my fuel pump relay burnt too??? Starter silenoid? Where can i find fuel pump relay? Thanks
Billyfinley79 is offline   Reply With Quote
Old 05-06-2018, 12:09 AM   #2
Year: 90
Chassis: international
Need more info to help. Engine, trans, gas, diesel, international, ford, etc.
Old 05-06-2018, 02:22 AM   #3
Asetechrail's Avatar
Coachwork: Amtran Genesis
Sorry couldnít resist...
[ATTACH]jakesteelairbrush[/ATTACH]
File Type: jpeg 7EA93371-A0C4-4320-98A8-8F2A71B4D534.jpeg (126.5 KB, 9 views)
Asetechrail is offline   Reply With Quote
Old 05-06-2018, 02:38 AM   #4
Flatnose, 5.9 cummings. Diesel. Allison tranny. Thank you.
Old 05-06-2018, 09:15 AM   #5
Year: 90
Magic smoke for a positive ground vehicle is very rare and expensive.
Your engine is a mechanical engine and most likely has a mechanical fuel pump. However the injection pump has a fuel shutoff solenoid in it. you may have nothing more than a blown fuel fuse. Check for fusable links near the battery too, may have cooked one.
Old 05-06-2018, 09:17 AM   #6
Year: 90
BTW, it's CUMMINS, not cummings.
Old 05-06-2018, 09:19 AM   #7
Roll Your Own Build Thread
Old 05-06-2018, 12:01 PM   #8
Yeah. Sorry. My phone is broke. Hard to see most letters. So where will this be located and thank you very much for yout help.
injection pump has a fuel shutoff solenoid in it. you may have nothing more than a blown fuse
Old 05-06-2018, 12:43 PM   #9
Year: 90
Check the fuse block. Might say fuel or ign.
Old 05-06-2018, 01:56 PM   #10
Fuse block is behind panel by my left leg drivers sides where all wires are??? Sorry. Im new to school buses but am a dirt bike guy
