Old 07-06-2017, 12:31 PM   #1
Engine: TE 444
Rated Cap: 12
Bluebird trailer wiring
Anyone here wired a bluebird for a trailer plug?
Hitch place had no luck finding the wires
Old 07-06-2017, 12:41 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
I haven't really thought about it but mine has the wires right on the back door of the engine compartment
Old 07-06-2017, 12:49 PM   #3
turf's Avatar
i've added in wires. i tapped into the box right outside the drivers seat. there was a single bundle of wires that headed to the back end. with a test light and someone flicking the blinkers on, it was easy to find.
there are some standard colors for the wires too. be sure to look at the car side of trailer wiring diagram.
here is a picture of the bundle with my wire taps on it.
Turfmobile Build Thread
Old 07-06-2017, 01:01 PM   #4
Chassis: Blue Bird
Engine: ISC 8.3
Hitch place didn't know where to look!
If it's a full size Blue Bird then the wires are bundled in the D-shaped chase at the top of the left/driver side wall. They run from front to rear in there, around the corner into the rear wall, and down to the lights. Likely crosses the rear exit door over the top, but I can't say I've opened one up there to be 100% confident. Anyway, intercept the wires in that chase on the driver side and figure out a route from there down through the floor.
Since the Blue Bird uses separate turn and brake lamps you'll need a combiner/converter box, same as is used for SUVs and pickup trucks that have separate turn signals. It's basically just a box of diodes. I can't tell you the wire colors off the top of my head but you can remove the brake and turn lamps and find out what color wire connects to each.
