Old 09-30-2017, 01:59 AM   #1
golfersmurf57's Avatar
Bluebird wiring schematics
I'm in search of wiring shematic( would prefer a week's rental of the service manual- payable in drinks) for a 1992 bluebird TC2000 pusher diesel. Surely some bus owner has one. I have ability to pdf it once I get one
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 09-30-2017, 08:38 AM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Each bus is spec'd different, so wiring will vary to some degree. My Cumins is a different beast than your Navistar, etc.
Go Here: https://www.blue-bird.com/blue-bird/...chematics.aspx
I like a nice, aged Rye....
PS: update your sig for more replies on ?'s.
Old 09-30-2017, 11:25 AM   #3
No Info
My 1990 comes up
No Wiring Schematics found.
My gauges show wrong readings if they show anything. (Except the speedometer. It works ok). I have a mystery battery drain. Also, at some point in the past, the electrical panel/box filled about 1/3 with water.
A general or similar tc2000 schematic of that year-ish would be a handy starting point.
Anybody actually have a pdf or some type of file of one?
There was a thread with one posted to a google drive, but it seems to be gone now (the file, not the thread).
Thanks
Cargo is offline   Reply With Quote
Old 09-30-2017, 11:30 AM   #4
Traveling
Rated Cap: '00
I got mine there. Here they be for 2003 Fe.
Old 09-30-2017, 02:12 PM   #5
Sorry rusty no rye for you. Mine came up no schematic to be found
Old 09-30-2017, 02:22 PM   #6
Cargo I'd start by checking all the gauge grounds on the dash ohm to battery neg should read close to zero its possible dash conneactor is corroded bad ground will make some guy guages read wrong
Old 09-30-2017, 03:05 PM   #7
Traveling
Rated Cap: '00
Works fine for me just today. I posted all my schematics in link above.
PM me your vin.
Old 10-03-2017, 03:33 AM   #8
Thanks Golfer. Will check the grounding.
Rusty, Yours is 13 years newer. Past some point they just didn't keep the info it seems. How may times has bluebird been bought and sold since they built my bus? Nearest Bluebird dealer tried and couldn't pull up anything either. Mine has no computer anything. It should be a very basic schematic. Still looking for something within a year or two. I appreciate the file though. At least I have something now.
edit: Coming through mostly corrupted. Only one file in the zip was extractable. Will try downloading the file again later.
Old 10-03-2017, 06:39 AM   #9
turf's Avatar
here is an older manual with some electrical in the last chapter or so.
this is about the best old reference i've seen.
https://www.dropbox.com/s/fm5b8amfrl...talog.pdf?dl=0
Turfmobile Build Thread
Old 10-03-2017, 10:12 AM   #10
Traveling
Rated Cap: '00
1) Find a similar model/year bluebird on govdeals and try that VIN
2)Try your body number
3) Call Bluebird, nice folks.
Old 10-04-2017, 10:52 AM   #11
Found Some
Don't know how much this will help but here is something.
1990 operators manual:
https://www.dropbox.com/s/orx5bhf71z..._1990.pdf?dl=0
1990-91 Wiring schematics:
https://www.dropbox.com/s/fp58zun7gs...90-91.zip?dl=0
This is my first go at a Dropbox account. Please let me know if the links work.
Old 10-04-2017, 04:12 PM   #12
Traveling
Rated Cap: '00
Links worked perfectly for me.
