Old 06-24-2010, 12:05 AM   #1
Year: 95
Chassis: GMC 3500
Engine: 6.5 diesel
Braun wheelchair lift wiring
I'm in the process of installing a braun millenium lift that I picked up at a local auction into my shortbus. I have it mounted and have tested it out manually with the hand pump a couple of times and it seems to work fine. So, I'm on to the next step of wiring it up.
I want to size the positive cable and circuit protection. I was wondering if anyone who has one or pulled one out of their bus can tell me what the amp draw for the lift might be? I don't see any info on the lift itself (I could be just blind too) and I can't seem to find much info on the web about electrical requirements for one of these.
I did find some diagrams that mentioned using Brauns "circuit sentry(?)" close to the battery, but they don't say the amp rating of the breaker.
Thanks for any help.
snonbos is offline   Reply With Quote
Old 06-24-2010, 03:13 PM   #2
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: Braun wheelchair lift wiring
any wheel chair lifts i have seen that are electric have cables going to them about the size of the negative cable directly off the battery all the way to the lift.
Old 06-25-2010, 01:31 PM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
I recently removed my lift and I can tell you the cable was huge. Definitely at least the size of a battery cable if not bigger. I'm not sure how far you are running to get to the battery, but mine is like 20 feet away.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-25-2010, 06:16 PM   #4
Year: 95
Chassis: GMC 3500
Engine: 6.5 diesel
Thanks for the responses.
Originally Posted by Smitty
Got a clamp-on DC ammeter ?
Smitty
unfortunately I don't have a clamp-on ammeter. I'll have to bum one and try the lift to get an idea.
If I were to put a decent load on it and run it with the ammeter, that amperage reading should give me the approximate circuit breaker and wire size to use?
The cable that was left on the lift was huge. That is what made me wonder what kind of amperage the lift is drawing.
I'm mounting it in the side door right behind the front door so if I were to run wire from the battery it won't be that far.
I had been thinking about mounting a aux. battery to run a small inverter for a laptop and some 12 volt inside lighting.
If I were to mount the Aux. battery setup by the control for the lift, I would think it would be fine to run it off of this battery?
Then I could probably run a smaller wire from the aux battery to the lift to power it? I would still need some sort of circuit protection.
I still have the large flasher relays installed in the cabinet above the drivers seat. They both already have a heavy battery 12volt supply to them. If I were to wire one of the relays to engage when the ignition is on to use it as an isolation relay. Then run the relay output to the positive side of the auxillary battery, would this be a way to keep the aux. system charged?
I'm sorta talking outloud here / looking for confirmation that I'm thinking correctly.
Old 11-25-2010, 12:57 PM   #5
Engine: 7.3 diesel
I know I'm late on this but for anyone else that asks,
2 gage wire should be used
Often up near the battery is a circuit breaker most of time they are 90 to 100 amp. The braun and ricon breakers in my opinion are better quality then those cheap ones you can find on ebay and would be worth the money spent on them. They serve in case of overload on the lift motor and in case of a wire short. They are installed on the positive side of the battery and the ground can be grounded to the frame.
Doesn't matter if it is an old lift or new lift they are all pretty simple and really don't require an "expert" to install. The bolts should go all the way through the floor and you may need to use some angle iron or something simular on the under side for better distribution of the load on the floor. but with our steel floors it isn't required just some big washers.
Old 02-07-2019, 04:25 PM   #6
new here. Question. I have removed my lift out of the bus using mostly bruit force and angle grinder. The question is the electrical running to the lift. As stated previously large gauge wire. But am wondering if I could attach that to my inverter/ converter for power while driving the bus? Any ideas?
Chiefw321 is offline   Reply With Quote
Old 02-07-2019, 05:05 PM   #7
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Rated Cap: 29,000
I don't see why that wouldn't work. It will only be powered if the ign switch is on or in the acc position, or at least that's how ours is wired.
Dave
Old 02-07-2019, 05:47 PM   #8
Year: 2010
Coachwork: Coach & Equipment MFG
Chassis: ford E350 superduty
Engine: 5.4 liter v8
Rated Cap: 7 passenger
the lift on my bus is powered on at all times and fed by a isolated battery(located on my e350 cutaway under the bus behind the stairs)your setup may be different but yes that would be a good place to feed your inverter. if it is fed by a separate battery your house system is already made for you (my lift battery is charged by the alternator when driving but isolated when ign. is off)
2010 ford e350 superduty v8 7 passenger bus
pbeggs is offline   Reply With Quote
Old 02-07-2019, 05:52 PM   #9
Year: 2010
it helps if you indicate what bus you have brand size gas diesel engine specs yadayada ect.but make and year we will either know the answer or we will find it we just need more info and some pictures helps sometimes but anyways welcome to the forum and good luck!
Old 05-21-2019, 11:32 AM   #10
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
I realize this is an "old" initial post, but need to figure out how my lift is wired.
It is the Braun mod. L205064PB. It is wired to work only when ignition is "on".
I need to somehow bypass the ignition safety, and rewire it to operate outside the ignition circuit. In other word's to have it function whether the bus is running or not.
Seems simple enough, but I can't find a Braun wiring diagram on this old lift to save my hind end!
Any help/suggestions are welcomed...
Old 05-21-2019, 11:49 AM   #11
ermracing's Avatar
Rated Cap: 29,000
We have the same issue with our bus. The solution I plan to put in place is to get a battery isolator and another regular car battery. I will put the isolator on the feed line to the lift, then to the new battery, then to the lift. This will keep the battery charged. When the ignition is turned off, the connection from the bus to the new battery will be broken, but the lift will still be powered by the battery. At least I think that will work.
Dave
Old 05-21-2019, 12:08 PM   #12
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
Thanks for the feedback ermracing.
I am hoping to not have to buy any additional gear to make this work.
I don't believe there would be a parasitic draw from the lift if it was wired direct to the battery. It has an inline circuit breaker already and it operates as designed, so it should work without going through the ignition circuitry, in theory!
So no need to add a dedicated battery from what I can tell so far.
I'm trying to keep it simple...?
Old 05-21-2019, 12:23 PM   #13
ermracing's Avatar
Rated Cap: 29,000
It would operate if you linked it directly, but you run the chance of drawing down your starting batteries if used enough. That is our concern and reasoning for its own battery.
Dave
Old 05-21-2019, 01:31 PM   #14
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
^...Great point!
I'm only planning on using it to get in and out of the bus, so it shouldn't discharge too much?
Just can't do that too many times without running it awhile to charge back up...
Old 05-21-2019, 02:02 PM   #15
ermracing's Avatar
Rated Cap: 29,000
For that amount of use it will be fine. Ours may be parked for a day or two and the lift might be used a bit for getting things into and out of our workshop so that's why I want a dedicated battery.
Unrelated question - can you open and close it from the inside?
Dave
Old 05-21-2019, 02:29 PM   #16
There is a remote control on a lead, once the door is open it doesn't matter where your standing to open the lift. It can be operated from inside by the person in the wheel chair.
o1marc is online now   Reply With Quote
Old 05-21-2019, 02:31 PM   #17
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
Tight fit between the lift & door but yes.
Old 05-21-2019, 02:35 PM   #18
Chassis: G30
Engine: 350 Chevy
Rated Cap: 10K
There is a remote control on a lead, once the door is open it doesn't matter where your standing to open the lift. Can't see much from the pic, but if you enlarge it you will see the cable at the bottom of the right side door frame on a 4' lead.
Mine lift is older, but the same basic design. The control pendant is on about 8' of a lead so I've got plenty of room to maneuver in or out of the bus.
Old 05-21-2019, 02:47 PM   #19
ermracing's Avatar
Rated Cap: 29,000
Same as ours, but have you rigged up a way to open and close the door from the inside?
Dave
Old 05-21-2019, 03:39 PM   #20
If it's hard to reach the handle you put a lanyard on it and a small pulley of some sort to pull the lanyard down to pull the handle up.
Removing wheelchair lift timmygyu Conversion General Discussions 11 08-21-2015 01:00 PM
Wheelchair Lift putterspitt Short-Bus Conversion Projects 7 05-25-2013 06:38 PM
wheelchair lift schoolmarm Classifieds | Buy, Sell, Swap 10 05-15-2013 09:00 PM
Braun Wheelchair Lift for Sale Diesel Dan Classifieds | Buy, Sell, Swap 0 03-20-2010 09:24 PM
New here and looking for a short wheelchair lift bus kdenault Classifieds | Buy, Sell, Swap 16 04-18-2006 12:35 PM
