07-17-2017, 12:58 PM
Chassis: Saf-T-Liner
Bus Battery tending?
Hey all,
My girlfriend and I are super new to owning any sort of vehicle that might sit around for lengths of time.
Our questions is this:
What (if any) sort of routine should we go through when parking the bus long term? Is there a smart way to maintain the Bus Batteries health for the longevity of always being able to fire it right up? About how long should we go between starting it before worrying about the batteries health?
We've leveled it out but that's an obvious thing it seems. We're not too mechanically/electrically advanced so any advice or a link to what we should even just buy would be greatly appreciated.
Thank you for your time!
07-17-2017, 02:26 PM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I'm assuming there are absolutely no loads on the battery and it is in good health. Typical lead- acid battery will self-discharge at about 5% a month at 60 degrees temperature. The colder it is the slower the self discharge... , it should be able to go several months without worry. However; if there are loads, you need to do something to ensure it does not become depleted below 50% state of charge. It would be preferable to connect to a "good" trickle charger of some sort to keep the battery fully charged. "Good" = a trickle charger that knows how to maintain a proper float voltage and not overcharge the battery.
07-17-2017, 02:32 PM
Wow so they're pretty much built to sit around all summer and fire right up I assume :P
I'd have to get a volt meter on it soon to check that they're in good health. 14.1 is the normal voltage that we want?
As far as I know, with the ignition completely off it's got nothing running from the battery. I assume that's what "no loads" means? Sorry I'm not the greatest with all this stuff!
Thank you for your reply!
07-17-2017, 02:37 PM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
There may be many things running from the battery without your knowledge. The clock in the radio, the engine ECU, some relay for something... These loads are often called parasitic or ghost loads. It is impossible to know unless you connect a meter to the battery and confirm. Or.. you can just use a trickle charger/small solar panel and not worry too much (until you know that the trickle charger is providing sufficient current to keep the battery charged).
07-17-2017, 03:43 PM
Awesome, thank you so much for clarifying that one. Hmm now to go ghost hunting! It's a 1993 Thomas Saf-T-Liner so I assume there's not too many modern gadgets running in the background, but I'll have to double check that one.
07-17-2017, 03:48 PM
Doesn't take much of a draw to end up being significant afer a few months of sitting. Another straightforward option is a cheap solar charger that plugs into your cigarette lighter outlet and gives you a little charge action while the sun is out. Just plug it in and let it sit on your dashboard and forget about it.
Here's an example: http://amzn.to/2t9oydn
07-17-2017, 03:52 PM
Chassis: IH
I was wondering about these solar chargers. I don't drive my Suburban much and the battery was weak on it last time I needed to move it. How well do they work? Might get one for ... wait, the bus doesn't have a cigarette lighter ... yet.
07-17-2017, 04:07 PM
The one I linked claims to have a 5 watt output. The Yuasa tenders I've had in the past were 6 watts in maintenance mode. It'd take a very long time to charge a dead battery, but keeping a full one healthy and full is a pretty easy job. It also comes with clips to connect directly to the battery but using a cig outlet is much more convenient in my mind.
07-17-2017, 04:14 PM
[QUOTE=Brad_SwiftFur;214888]I was wondering about these solar chargers. I don't drive my Suburban much and the battery was weak on it last time I needed to move it. How well do they work? Might get one for ... wait, the bus doesn't have a cigarette lighter ... yet.[/QUOT
My Suburban does the same if not driven pretty regularly. If I disconnect the ground for the battery it won't discharge but then it has to relearn how to shift being an automatic. This can take a day or so depending on mileage but sure is a bother.
Those solar chargers do require a voltage controller as they are able to overcharge when not attended to.
07-17-2017, 04:26 PM
A charge controller between a 5 watt charger and a bank of Group 31 (or similar) batteries seems like over engineering to me, but it would be technically better.
07-17-2017, 04:41 PM
Someone mentioned a device here on the forum recently and I cannot remember the name of it.
It is a solar battery maintainer and desulfator. Apparently he was exposed to them in the Army. They used them on trucks & HMMV's that sat unused for extended periods.
Maybe they will chime in/
07-18-2017, 09:26 AM
Coachwork: Thomas/International
Chassis: 3700
Engine: 7.3
Depending upon the size of the battery and the cable run length a 5 watt panel may not even keep a battery topped off, 10 watts is probably better, but what ever you get you will want to test the voltage of the battery at least weekly for the first few months to make sure your particular setup is working. AM before the sun is up is best time to see what the resting voltage is
my bus thread, https://www.skoolie.net/forums/showthread.php?t=8860&highlight=bubb
