Old 06-28-2017, 07:17 PM   #1
Can anyone tell me what this is? Pic
I'm looking for the ODBII port on my bus and I came across this which had some wiring harness plugged into it that said Zonar, I have no clue?
CuddlyBurrito is offline   Reply With Quote
Old 06-28-2017, 07:38 PM   #2
turf's Avatar
trucks don't use obdii, they have their own protocol. j1939 or j1708 are the truck connectors
Turfmobile Build Thread
Old 06-28-2017, 07:45 PM   #3
So what am I looking at here, and is there a good thread on how to pull a check engine code or clearing them?
Old 06-28-2017, 07:51 PM   #4
turf's Avatar
im no help. my truck is mechanical.
but a quick search on 'zonar' says its a gps tracking device.
someone with some modern diesel experience can answer better than me, some day i'd like one of those fancy data readers
Old 06-28-2017, 08:06 PM   #5
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
What kind of bus?
Old 06-28-2017, 08:31 PM   #6
Originally Posted by Njsurf73 View Post
What kind of bus?
2002 Freightliner Thomas body 5.9L with Allison 545, it had a lift in the back and was not full length.
Old 06-28-2017, 08:38 PM   #7
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
In addition to GPS tracking, ZONAR also has a system of RFID chips/reader to verify pre operation inspections. My bus had a bunch of half dollar size ZONAR RFID chips inside and out at every inspection point. I think the driver carries a RFID reader with them that verifies the inspection. So I suspect your device was related to GPS and vehicle operation data collection. Should not affect vehicle operation. I'm pretty sure the short cutaway style busses (i.e. based on E350/E450) have OBDII
If it isn't grown, it has to be mined
elkoskoolie is offline   Reply With Quote
Old 06-28-2017, 08:47 PM   #8
Yeah I pulled apart the whole dash and followed all the wires thinking I would find an ODBII l, I was just an idiot and pushed a switch by the steering wheel that said "engine check" and when I hit it the check engine light came on, it's not ever been on since I've had it and now can't get t off
Old 06-28-2017, 08:51 PM   #9
Chassis: E350
Rated Cap: 24
Push the switch again? Push and hold 'til light goes off??
Old 06-28-2017, 08:53 PM   #10
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
It may stay on for a set amount of time... Like 100 miles, or x amount of start cycles. If it wasn't on before it likely doesn't mean anything.
Old 06-28-2017, 09:06 PM   #11
I thought it would be too, but I've just about driven 120 miles and started up about 20 different times in the past week
Old 06-28-2017, 09:12 PM   #12
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Have you tried a Google search...
Old 06-28-2017, 09:16 PM   #13
Yes right when it came on, finding bus stuff is hard, since it didn't o off after 100 miles I'm turning to the forums
Old 06-28-2017, 09:26 PM   #14
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
My "service engine soon" light came on when I bought my bus. The mechanic hooked it up and it was a reminder light that I needed to change the oil. It went off about 200 miles into the trip home (the oil had been changed at the dealer that morning) and hasn't come on again.
Old 06-28-2017, 10:06 PM   #15
2kool4skool's Avatar
It's a j1708 plug, plugged a Scangauge D into mine and I can read and clear codes and much more.
Don, Mary and Spooky the cat.
Old 06-28-2017, 11:12 PM   #16
There we go! I've got one in my amazon cart need to pull the trigger now
