Old 07-23-2015, 02:00 PM   #1
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
Charging batteries while hooked to inverter
I have currently one large deep cycle battery and one 1100w inverter. Can I leave the inverter hooked up and powered on and in use while I charge the battery with a regular maintenance-free mode charger hooked to the generator?
My build thread:https://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
onenationundergoat is offline   Reply With Quote
Old 07-23-2015, 03:25 PM   #2
bubb, the real one's Avatar
Coachwork: Thomas/International
Chassis: 3700
Engine: 7.3
yep, charging and draining a battery at the same time is the way most use them
my bus thread, https://www.skoolie.net/forums/showthread.php?t=8860&highlight=bubb
bubb, the real one is offline   Reply With Quote
Old 07-24-2015, 09:56 AM   #3
Chassis: Thomas
Rated Cap: 60
Ok good, just making sure I wasn't gonna blow up my inverter!
Old 07-24-2015, 10:48 AM   #4
Chassis: 3700
Engine: 7.3
I should have mentioned before, especially if you will be using the setup long term,
Refer to the inverters manual, it will probably want you to put a 60 to 80 amp fuse or breaker on the positive wire that feeds the inverter from the battery,
It may have other advice or requirements on how to safely charge while discharging specific to your inverter.
Old 07-24-2015, 04:38 PM   #5
Chassis: Thomas
Rated Cap: 60
It didn't mention anything about charging while using, but the inverter I got came with 4awg cables and a fuse already on the positive cable.
