04-06-2019, 03:41 PM
#21
Originally Posted by brokedown
I originally bought the 4375 for my bus and my friend bought the 3500 for their bus. Bought them at the same time that Saturday. Was a great opportunity to compare them.
Did you swap or do you have one of each now?
04-06-2019, 03:48 PM
#22
I returned the 4375. No restocking fee if you are getting a more expensive model to replace it... So now we both have 3500s.
04-06-2019, 09:48 PM
#23
Excellent, I'll have to remember that!
That is the unit we were looking at a little while ago. Since we do not NEED it right now, we decided against the purchase (right now).
04-06-2019, 09:53 PM
#24
Putting my money where my mouth is, I have purchased the super quiet 3500. Got some new unrelated injuries this morning so I won't be setting it up for a few days.
Well dang it!
Wishing you a speedy recovery!
04-07-2019, 05:10 AM
#25
Coachwork: Bluebird, Collins
Has anyone tried a exhaust attachment that goes straight up above the roofline with muffler pointed towards the sky? I saw a picture somewhere and wonder how effective it is?. I think it was a Honda modification.
04-07-2019, 06:56 AM
#26
You have to be careful with exhaust routing, they recommend at least 5 feet away from your structure. I would worry more about horizontal distance. It won't do anything about the noise level though!
04-07-2019, 07:57 AM
#27
Originally Posted by joeblack5
However quiet a generator can be it is very noticeable and disturbing in natural areas. It is unfortunate that with all the beauty around many people seem to have a need to run a generator to watch their movie. Also the air pollution of these generators is pretty extreme. I would image that the propane units are the best in that regard.
I have a need to sleep with A/C in summer.. so alas why I use a generator if I overnight.. its either that or I have to run the diesel engine... whicbh is worse for noise and environment?
I tried running my portable A/C on my battery bank and I get a couple hours and dead.. I think propane burns much cleaner it seems than gasoline does..
roughing it with summer sweat is probably the cleanest methodology to the environment...
04-07-2019, 10:05 AM
#28
It has been proven the changing the muffler makes little if any difference in noise reduction most of the noise comes from the motor itself and not the exhaust system.
04-07-2019, 07:39 PM
#29
Year: 98
Jack , that might be true. Comparing generators in itself is fine. Without the purpose of use it all depends on the background noise. If you are at a truck stop one is acceptable ...if you pull up 1000ft next to a tent camper at a quiet lake dB's get a very different meaning, especially if one has the urge to run it for extended time. Compare needs to include your mission.
Johan
04-07-2019, 09:27 PM
#30
Joe, your problem--not mine-- not bad, just not what the post is about. Start your own, Its Ok.
04-07-2019, 10:44 PM
#31
Year: 98
No worry jack. Thanks for putting a sound dampening box around me. How many db did you achieve. At least you come thru loud and clear.
