Old 03-28-2017, 11:41 AM   #1
Confused on air conditioning.
Hello everybody, I've been lurking here for awhile learning what I can. I have been planning on building a skoolie for a couple of years now, and now that I am going to retire in the next year or 2 I'm about to start getting serious and start buying what I need. Me and my wife have been thinking about what we wanted, and we have figured that we are most interested in boondocking and being very independent. Now we are happy with the smaller space, but we are not willing to give up our creature comforts. For us that means AC among other things. So I have been looking for info on running an AC on solar power, but it seems that the general consensus is that it's not possible/not worth it on a schoolie or rv. Now I'm planning on designing around my planned electrical loads, and I'm earmarking up to $7000 on the power system, tho hopefully it won't run that much.
So here is my idea so far. I want to use household appliances on a 115v system, I don't see much or any need for dc appliances. My plan is a 48v system based on 8 6v batteries(leaning towards the t105 re's atm) and an inverter feeding a 115v power panel that has the place set up like a traditional house. I plan on at least 1000w of panels or more if needed. I do plan on having a small generator, but I want it more as a emergency backup and not something I have to use very often. I have in my house a small 5000btu window ac that says it uses 550 watts. It keeps my livingroom, kitchen and hall area fairly cool here in west TN. So I'm thinking that will probably be enough to keep us reasonably cool when we get caught in hot weather.
Now if I have 8 t105's I'm looking at about 900 amp hours at 50% of my battery capacity. Figure 10% resistance and inverter loss gives me about 800 amp hours. My ac(or one like it) would be pulling say, 600 watts. So 600/48=12.5, and I believe the numbers they give you is 100% duty cycle. So if I understand right, the most it would draw in a day, running full blast is 300 amp hours from my batteries. But that seems awful low for everybody to be saying that AC on solar is just not practical, so I feel like I'm missing something. Could somebody please tell me if I'm all messed up on figuring out how this works.
Thanks in advance for any help.
Anzid is offline   Reply With Quote
Old 03-28-2017, 11:57 AM   #2
Engine: Detroit Diesel 6-71
Rated Cap: 52 pax
I too will be using a 48 volt system. as you have calculated, the higher the voltage of the system the more storage you get out of the same batteries. To be honest, I know nothing of solar design and have a solar guru designing my system. He has designed off grid systems for my cabins and a solar well pump with battery backup for my dads ranch. He explained it all really well but was using all these big works and calculations with big numbers and he was talking fast.... I understood little but he's the pro. I'm interested in following this thread to see how you build yours.
-Chevy
Chevydude01 is offline   Reply With Quote
Old 03-28-2017, 12:37 PM   #3
The T-105 is rated at (20hr reate) 225AH. So, 8 T-105's in series will yield a 48 volt 225AH bank. Assuming a max 50% discharge you would have 112AH @ 48v available.
If you connected 8 T-105's in parallel then you would have a 6 volt 1800AH bank.
Series=Add voltage of each battery. AH rating stays the same.
Parallel=Add AH rating of each battery. Voltage stays the same.
To get 48v @ 1800AH you would need 8 series strings of 8 T-105's connected in paralell. 64 T-105's... That is A LOT of batteries...
I would suggest that you start with the AC and an https://www.amazon.com/P3-P4400-Elec...ds=kill+a+watt .
Run the AC for a few days in conditions that approximate what you expect to see when traveling and see how much power the AC REALLY uses in a day. Then size your solar & battery bank accordingly.
for most of us, running AC from batteries is not practical because of the size of battery bank required.
I did see one AC install that they called "hybrid". They had a solar install big enough to run the AC on its own when the sun was shining strong and a smaller battery bank to "buffer" during the occasional cloudy spot. The AC was a 12 volt mini-split and only 6k btu.
PNW_Steve is online now   Reply With Quote
Old 03-28-2017, 02:38 PM   #4
Chassis: Blue Bird
Engine: ISC 8.3
For your use model it might be worth considering LiFePo (lithium, but this is not the same as Li-Ion) chemistry instead. It endures much lower depth of discharge, faster recharge, and may yield more cycles aka longer lifetime than the lead batteries would. It's worth investigating.
The adequacy of a 5000 BTU air conditioner is suspect. Factory insulation and air sealing in a bus are terrible in comparison to a conventional home. To achieve the temperature control you're accustomed to through an entire bus you'll need much more than a 5000 BTU air conditioner or to substantially improve the insulation and air sealing.
Old 03-28-2017, 03:04 PM   #5
bubb, the real one's Avatar
Coachwork: Thomas/International
Chassis: 3700
Engine: 7.3
the issue is AC vs DC, your 5000btu unit probably pulls 4.5 amps AC but,
1 amp AC equals about 10 amps DC, which means the unit will pull around 45amps DC to run,
Lets not even talk about electric motors LRA on startup,
my bus thread, http://www.skoolie.net/forums/showthread.php?t=8860&highlight=bubb
bubb, the real one is offline   Reply With Quote
Old 03-28-2017, 03:06 PM   #6
brokedown's Avatar
Running air conditioning from solar is pretty unreasonable. Your entire build will end up being designed to support it, at the expense of other features. Look into generators or engine driven solutions. Electricity is terrible for heating or cooling.
Old 03-31-2017, 04:25 AM   #7
Thanks PNW_Steve, that was the mistake I was making. I was thinking the amount of battery power my math was getting me looked too good, I don't know why I was multiplying amps with voltage. So it looks like ac will be genny or shore power only.
Old 03-31-2017, 07:02 AM   #8
Phatman's Avatar
As an electrician for the last 42 years, I will tell you electricity is the most inefficient way of doing anything. It's not to say that electricity is not good, sometimes it is the only way. Family Wagon is right though about the 5000btu a/c. GOOD LUCK ANZID
Old 03-31-2017, 08:34 AM   #9
joeblack5's Avatar
Year: 98
Besides the technical correction PNW and the practical recommendation from family wagon regarding insulation and lithium only more solar will help.
I think the 90% inverter efficiency/ losses are a little optimistic. I would take 85% . That is a real life number from out battery backup solar at our home. the inverters are outback gvfx3648.
Some inverters "without heavy" 60Hz transformers can be more efficient .
Not sure what bus you are looking for but we used to have 600 watt on an ambulance econoline van and ran a 500 btu window unit at 30% duty cycle during the day.
Our current built will support 900 watt of solar and we are set up for 48 volt lithium at 120 Ah from a Nissan Leaf.
Depending on in what climate you are I think it is very well possible to run your AC on solar... and solar is very cheap nowadays. generators, fuel tanks, maintenance, noise... just not from this time anymore.
Check out small split heat pump systems so you can use some of the heat as well.
Later J
Old 03-31-2017, 09:24 AM   #10
dredman's Avatar
Have you ever thought of simply MOVING towards cooler, dryer weather when things heat up? That has been my strategy for the last 2 years, and I am rarely uncomfortable. Mountains do a hell of a lot for temps, and those wheels come in handy for moving around. Chasing weather sounds extreme, but nowhere near as extreme as trying to cool a school bus with batteries?
My Skoolie Story on YouTube
dredman is offline   Reply With Quote
