Old 03-03-2019, 01:17 PM   #1
TeacherJoe's Avatar
Engine: Cat C7
Crazy Wires!
Iím not sure if this is the right sub forum...but can anyone help me figure out this mess in the fuse panel area?
Joe
File Type: jpg 541949DD-5602-45B9-B016-A3DC0BE098EA.jpg (182.9 KB, 15 views)
File Type: jpg 0D08DF02-64F7-4702-828E-4623470CC37D.jpg (131.4 KB, 9 views)
TeacherJoe is offline   Reply With Quote
Old 03-03-2019, 01:39 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Those are generic cube relays. Either follow the wires to the other end or have someone flip switches to see what makes them click. Start with any switch that doesn't look original.
Old 03-03-2019, 02:11 PM   #3
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
As previous response says, they are relays. Assuming they are still needed, you could just bundle them up and secure them. There are so many relays on a bus that there is no way to hazard a guess at what they are for without more info.
Any electrical device that uses more than few amps will use a relay to keep they heavy amp load off of the primary switch.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
