Old 01-17-2017, 10:28 AM   #1
Dash lights not working.
Just wondering if anybody has any idea why my dash lights are not working. The guages work but the lights are not. Hmmm.
1991 BB flat nose BTW.
JHerrin is offline   Reply With Quote
Old 01-17-2017, 10:58 AM   #2
Rated Cap: Your mom +1
check the electrical grounds for your dash lights, they like to rattle loose sometimes...
Old 01-17-2017, 11:46 AM   #3
I found ONE bulb and it checked out. It does not seem to be getting power though. Oh boy...electrical. F%$# off.
Old 01-17-2017, 02:45 PM   #4
Yeah electrical gremlins suck, but there are some very knowledgeable people on here that can hopefully point you in the right direction... I'm no expert but since it doesn't seem to be getting power check the fuses and or breakers next... If you don't have one, a test light could probably help find the problem, plus they're pretty inexpensive.
Old 01-17-2017, 06:27 PM   #5
warewolff's Avatar
This is an easy fix! Take your cluster out and re solder all the major pin connections. You probably don't even have to add solder
... just hold the iron on until it re liquifies. I did it with mine ... there is a rebuild thread here somewhere.
warewolff is offline   Reply With Quote
Old 10-22-2018, 09:17 AM   #6
Rogue1bus's Avatar
Trying to find the rebuild thread... post a link if you find it please.
Rogue1bus is offline   Reply With Quote
