Old 04-23-2017, 07:51 PM   #1
Diesel Tach
Has anyone found a reasonably priced tach? I'm after the type that utilizes the alternator.
tlbeck1985 is offline   Reply With Quote
Old 04-23-2017, 09:44 PM   #2
turf's Avatar
i got one for $10 off of ebay. works fine!
http://www.ebay.com/itm/52mm-0-6000-...item35f0c13bbd
find the stator on the alternator and run the wire.
its not terribly accurate but relative is better than nothing.
Turfmobile Build Thread
Old 04-26-2017, 08:45 PM   #3
Thanks man. Any idea how accurate it is though?
50 day shipping? I went to buy one and canceled it lol
Old 04-26-2017, 09:01 PM   #4
turf's Avatar
mine came in just a few days, pretty fast considering it came from china.
i don't have a way to calibrate mine yet. i just guess that idle is about 500 and redline is about 2700.
the dial stays in between the 2 mostly, but once it did read up in the 3000's. i let my foot off the pedal and than back on it again and it re-established at 2700.
there is a 3 way switch on the back of the tach to get it into the right range for the alternator, then there is a screw for fine tuning.
its close, well worth the $15. my next down hill run will will be more confident with the trans being able to hold a constant rpm number.
Old 04-26-2017, 10:04 PM   #5
Not $10 bucks but quite accurate and easy to install on any diesel...
https://www.tinytach.com/diesel-tinytach
Old 04-27-2017, 05:28 AM   #6
Dang, with the transducer that ends up being more expensive than an autometer gauge. https://www.summitracing.com/parts/atm-2888/overview/
Old 04-27-2017, 05:30 AM   #7
In case anyone hasn't seen how they make your tach work off the alternator
