Old 01-15-2018, 11:48 PM   #1
Coachwork: Amtrak RE
Chassis: International 3000
Engine: T444e
Does this make sense for a battery bank?
I want to make sure we have the wiring diagram correct and this makes sense as a system. I purchased most of the components already, but if you have a strong recommendation that I change things, it's not too late to do returns.
1. Does this make sense? Is anything installed in the wrong place or the wrong way to work?
2. Did I create a short or something dangerous? Do I need more fuses or different fuses or in different places?
3. Is this appropriately flexible to later be able to add solar power, a generator, or more batteries if we decided to do so down the road?
4. What gauge wiring should I use? My reading sounds like 8 gauge is sufficient but 4 gauge is recommended. Does this sound right? Does the wiring requirement change if I later add solar power?
5. I will need to winterize next September. If we plan to not use the bus, the recommendation seems to be to bring the batteries inside. If we want to go somewhere in Alaska in the winter, what are your recommendation to keep the batteries functional at -20 to -50 degrees Fahrenheit outside? Are there any other components I should be worried about in the battery compartment?
Thanks
Biscuitsjam is online now   Reply With Quote
Old 01-15-2018, 11:49 PM   #2
Engine: T444e
More information:
Charging: a 4-stage battery charger (Iota DLS-45) while connected to shore power or from the alternator while driving (Sure Power 12023A Isolator). I've read that I may not get much charging power off the alternator this way while driving - thoughts? In an emergency situation, I could idle the bus (about 2/3 gallon per hour), but I don't know if I could get enough power that way to be worthwhile.
AC Power: Automatically switches to use shore power when connected (Xantrex ProWatt SW Auto Transfer Switch). Otherwise, I will be using a 2000 watt true sine wave inverter (Xantrex ProWatt 2000). Running off AC power will be a residential refrigerator, the control panel for a gas stove, a 700 watt microwave, a crock pot, a laptop computer, a coffee maker, and some outlets (and possibly a washer/dryer, but I don't think I want to give up the space. No air conditioning needed in Alaska).
D/C: Running off DC power will be lights, CO/smoke detectors, the composting toilet vent fan, and water pump(s) (and possibly some control systems for our heating solution - haven't finalized it yet).
Battery Bank: 4x inexpensive golf cart batteries give me 430 A/H at 12 volts (Duracell GC2). This should allow us to boondock for a couple days if we are frugal on electricity.
Disconnects: A manual disconnect in the battery compartment (180A continuous/1000A Surge Disconnect Switch) disconnects everything (I've heard that it is a bad idea to turn off while the engine is running). A Remote Inverter On/Off Switch in the cabin turns off AC Power but does not disable DC power (Xantrex ProWatt SW Remote Switch).
Battery Monitor: An inexpensive unit that monitors voltage and the current (Bayite DC 6.5V-100V LCD). I think it is sufficient for now, but it wouldn't be hard to swap out later with a Trimetric if I think I need it.
Fuses: One in-line fuse at shore power and one in-line fuse just after the battery bank. Is this sufficient? (ANL-500A). Currently, I do not have plans for any circuit breakers inside the cabin and was instead planning to just use surge protectors on A/C for this initial trip (the cabin will have appliances, bedding, and seating installed but will not really be "finished" until arrival in Alaska).
Old 01-15-2018, 11:56 PM   #3
Chassis: Saf-T-Liner MVP ER
From the shore-power, the power comes in at 110-120V. The fuse should be 30 to 50 Amps, not 500 Amps. The larger fuses are usually only on the 12V side of the system.
Steve Bracken
Build Thread
Old 01-15-2018, 11:58 PM   #4
Engine: T444e
Makes sense - that's an easy change.
Old 01-16-2018, 12:04 AM   #5
Thanks for that. Electric are not my strong suit and I was hoping to find a diagram like this before I got started so I would know all I needed and where to put this. This helps tremendously.
Old 01-16-2018, 12:43 AM   #6
Defjr333's Avatar
Chassis: Shuttle or Shorty. Still hunting
Engine: Prefer Diesel
Rated Cap: 14 to 24 pref
Just a question....Why did u go with separate transfer switch, charger, and inverter? Preference? 2K watt inverter/ chargers with built in transfer switch makes for much easier install, plus saved me $......mine was $730. And btw, go with 0awg minimum. 00awg if u can. Also keep the power cable from battery bank to inverter as short as possible....under 5 feet mine says @00awg. Its 3k watt tho. Hope gave some ideas.
Doug
Defjr333 is offline   Reply With Quote
Old 01-16-2018, 02:07 AM   #7
Engine: T444e
The charger, inverter, and transfer switch were $620 altogether for name-brand components, (plus $25 for the remote power switch) although I just discovered I could have saved $75 or so by shopping around more. If something fails or I want to do an upgrade, I donít have to replace the whole system.
On the flip side, the wiring could get expensive and that big gauge stuff isnít a lot of fun to work with.
This chart is interesting, though it doesnít show the big gauge wires:
https://www.windynation.com/cm/wire_size_fig3wn.jpg
Old 01-16-2018, 07:26 AM   #8
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Yes, makes sense. If one were to get picky, AC power is not really +/-, it is hot, neutral, and ground. Not a big deal from a diagram perspective - just be aware when you start connecting things.
The important point to remember about fuses is that they are there to protect the wire. Therefore; they are placed at the 'power source' end of every (in theory) wire (e.g. battery).
Yes, solar is simple to wire in as the output from the charge controller connects to the battery bank.
It depends on the power that must pass thru the wire and the length of the wire. Use any of the online wire size charts (or size calculators) to determine the correct size to achieve a 3% voltage drop (or less). For example, with a 2000 watt inverter, you can expect to pull 2000 watts from the battery bank (at full load). At 12.5 volts, this is 160 amps. If the wire/cable length from battery bank to inverter is five feet or so, you would need 2/0 cable.
In the case of AC wiring, assuming a 30 amp (at 120VAC) input, 10-2 wire is sufficient. If you are plan to push that 30 amps and your length is long, you might consider 8-2.
I've been told that a battery will sit unused at those temps without any problem. However; it is not good for the battery when you start discharging/charging at those temps. I would bring them inside if that is an option. Nothing else comes to mind as being temperature sensitive.
Doug; regarding your question... I went with separate inverter/switch so I could replace one without having to replace the other - assuming they both will not fail at the same time.
JD - Full timer out west
My Adventures & Build
Old 01-16-2018, 09:53 AM   #9
Defjr333's Avatar
Great stuff. Yeah, no wrong way about it.....just figured I would ask if it was a specific reason. Upgrades are def a reason
Doug
Old 01-16-2018, 11:14 AM   #10
Engine: T444e
So, let's see if I got this right?
- 2/0 for all the wires connecting the batteries and to/from the charger, isolator, inverter, and ground.
-8ga for all the AC wiring (cabin power, plus shore power to/from charger)
-12ga for all the interior DC wiring (to lights, smoke detector, etc.)
-50amp in-line fuse for 120 VAC input, 500A in-line fuse for 12 VDC output
1. Do I need to add circuit breakers for the cabin wiring?
2. Should I ground the AC wiring? If so, where do I insert that in my wiring diagram? There is lots of stuff about wiring the circuit breaker panel ground to the chassis and making sure the neutral isn't bonded to the ground. If no circuit breaker panel, then what?
3. Is an in-line fuse sufficient for the power input? I see a lot of articles about people buying $400 Autoformers or $100 surge protectors.
