Old 05-19-2017, 08:08 PM   #1
Coachwork: Blue-Bird
Engine: 5.9
Electric load issue
My bus has a refrigerated cooler chilled by an air conditioner controlled by a device called a coldbot. Using my generator today to run a test I ran into issues. The generator is a DuroMax XP4850EH Hybrid Portable Dual Fuel Propane / Gas Camping RV Generator. 30 amps, 4850/3850 watt. wired to a breaker panel through a N-G bond. then a 20 amp circuit to the
A/C. At first no cold air out of A/C then 30 amp breaker on genny pops.
I am going to open everything and check all wiring connections.
Any ideas or help?????
David Moose
Moose is offline   Reply With Quote
Old 05-20-2017, 08:12 AM   #2
Good idea to open the A/C right up and besides checking connections, give it a good cleaning. Can you read any nameplate data for it. Does the fan itself work? Could be there is low refrigerant due to a leak somewhere.
I think your gen should run it fine but any motor at startup draws three times the amount of current that the name plate says. For example if the nameplate says it takes 12 full load amps to run then you are looking at 36+ amps till it comes up to speed. Could be a seized compressor if it won't start without tripping.
What is the make and approx age of the unit?
