Old 06-18-2019, 11:20 PM   #1
Entry Gland Location
Does it really matter? Would up on the roof where it will be under a panel be better than if it was down an the curved side? I know I want it right over the electric room and I can wire it later to the panels when I mount them.
Old 06-18-2019, 11:42 PM   #2
Year: 90
Chassis: international
I think you need to give more details. Not sure what you are talking about.
Old 06-19-2019, 01:14 AM   #3
Are you talking about the interface between the outside and inside?
Old 06-19-2019, 01:28 AM   #4
Yes, commonly referred to as an entry gland.
Old 06-19-2019, 02:07 AM   #5
I am thinking that as long as the seal is maintained, you can locate it most anywhere. I would think the only real exception is mounting it upside down so that the wire entry points would be exposed to the elements.
Old 06-19-2019, 06:10 AM   #6
Johnny Mullet's Avatar
Engine: T444E 7.3L
I put mine right in the middle on top of the roof next to my panels. Made sure it was sealed up good......
27459373_1774429492599974_64174643069552204_n.jpg   27067121_1777205362322387_5467308195961796524_n.jpg
Old 06-19-2019, 01:46 PM   #7
I have mounted them on the roof under one of the panels.
I mounted them with the glans facing aft.
Plenty of buytl tape.
No leaks
Old 06-19-2019, 03:36 PM   #8
HazMatt's Avatar
Chassis: IH 3800, 8 window
No leaks
I bet that makes your bus walk in a peculiar manner... 🤢
Old 06-20-2019, 03:33 PM   #9
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Go away. 'Baitin.
Our Build: Mr. Beefy
