Old 07-11-2018, 11:30 PM   #1
Coachwork: Aerotech
Chassis: E-450
Full Inverter/Charge kit to buy??
Hey folks- first post here. Does someone offer a full kit to purchase (inverter,leads, switches, shoreline hookup, alternator hookup etc.) for charging battery bank to power AC/DC? First time conversion here and I'm looking for something simple to get started with. Thanks!
Foxpen is offline   Reply With Quote
Old 07-12-2018, 05:04 PM   #2
Coachwork: Aerotech
Chassis: E-450
Ha! Doesn't exist, eh?
Old 07-12-2018, 05:19 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
One DOES exist. Contact your local RV dealer.
Old 07-12-2018, 08:06 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
I built a setup like that using an Aims pure sine wave inverter/charger/transfer switch as the hub.
From there I just bought the shore power inlet, a voltage sensitive relay for charging from the alternator, and the wires, breakers, and batteries.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 07-13-2018, 06:23 AM   #5
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Originally Posted by Foxpen View Post
Does someone offer a full kit...
Not that I'm aware of but I was wrong one other time.
It seems we kinda hate to admit it but a conversion is not a simple thing - certainly not a "full" conversion to a livable RV style rig. Of course, it isn't rocket science either - just stuff that many folks have never messed with before. The electrical system is one of the areas that tends to give folks problems. In my opinion, it requires a lot of decisions, a big learning curve, an actual plan/design, and far more research/study that many want to give it. However; this knowledge is valuable (I'd even suggest essential) for then living with the conversion.
So... start studying and asking questions.
JD - Full timer out west
My Adventures & Build
Old 07-13-2018, 09:00 AM   #6
Coachwork: Aerotech
Chassis: E-450
Thanks for the replies! I know there’s no “easy button”, but I wanted to make sure I wasn’t missing something simple.
Old 07-13-2018, 12:36 PM   #7
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I bought one of those red easy buttons and I think mine was inoperable on receipt. At least it didn't work as I expected.
There is a product - not sure who makes it or what it's called - that is basically an AC/DC power panel. It includes 110VAC breakers and 12VDC fuse panel. Maybe more, I'm not sure. I think it is used in the smaller RV's. Certainly not everything you listed originally but might be a starting point??
Something like this but I have no idea if this is a good one or commonly used - just the first thing to pop up in a search.
https://pantherrvproducts.com/atwood...waAs4bEALw_wcB
Old 07-13-2018, 11:38 PM   #8
Chassis: Thomas
Engine: CAT 3126
It is generally called an RV power converter. I had one I recovered from a wrecked trailer but sold it. For the right build though they are convenient.
My Build Thread:
Old 07-14-2018, 08:47 AM   #9
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Thanks for the replies!... I know there’s no “easy button...
Sigh. I was hoping...
Dapplecreek is offline   Reply With Quote
Old 07-14-2018, 01:27 PM   #10
Coachwork: Aerotech
Chassis: E-450
Thanks guys- very helpful! Picked up our 99 E450 shuttle yesterday. So I’ll be picking your brains on lots of topics I’m sure.
Old 07-25-2018, 04:44 PM   #11
Coachwork: IC
Chassis: CE
Engine: dt466e
Rated Cap: 65 passenger
Contact Charles Kern at chromeyellowcorp.com. He will make whatever you want.
atthebeginning is offline   Reply With Quote
Old 08-03-2018, 02:30 PM   #12
golfersmurf57's Avatar
Wait a min JD! I happen to be pursuing a career as a rocket science demonstrator. Like when u take 2 same size cut boxes at aldis - cram one inside the other and now have a full box! These and other smurfisms are available upon request. No it's not rocket science. There are a few folks who manufacture power distribution panels for a.c. & D.C. also with or without shore power converters and coach battery chargers. I'm still shopping for mine. But I've looked at progressive dynamics, parralax, and Atwood. Start with those and have about $400 to toss in the yellow metal bin that You're throwing money into.
golfersmurf57 is offline   Reply With Quote
