Old 02-27-2017, 03:00 PM   #1
Engine: T444e
Rated Cap: 35
Fuse Panel Diagram - Pics Needed
I have a 2001 International Amtran conventional bus and the wiring diagram that should be in the outside door under the drivers window has been peeled off. I understand that they may not be exact, but I am looking for a good quality picture of the diagram from someone else's bus of similar make and year to help with identifying which fuse is which. Thanks.
bstewrat3 is offline   Reply With Quote
Old 03-05-2017, 06:06 PM   #2
Engine: T444e
Rated Cap: 35
I have noticed that all of the wires have numbers for each circuit. Is the numbering standard across the Amtran builds?
Old 03-14-2017, 05:35 PM   #3
I've not found a good reference for the body which is what you are referring to. On my 1992 international it has a fuse panel under the steering wheel and the other outside under the drivers window. My body is a ward senator. I've also noticed the numbered circuits but I'm not sure how far they went in keeping them uniform through year model changes. For example, on my 1992 all of the marker lights are wire numbered 2. My fuses are labeled but the wiring diagram in the little pocket is in rough shape. I brought it in out of the weather and plan to scan it. I could do that and share it and the fuse pics but mine is quite a bit older than yours. I'll share what I have for reference sake but you'll have to be careful and verify things.
ironrule is offline   Reply With Quote
Old 03-14-2017, 06:42 PM   #4
This may not help at all but here's my fuse panel outside the driver window. Like I said, it's 1992 so take it with a grain of salt. I'm looking at my wiring diagram to scan but it's pretty useless, very badly faded. I'll see what I can do with it.
Edit: BTW, the right side of this pic is actually the bottom
Old 03-14-2017, 06:50 PM   #5
Looks just like my 92 Senator. If only my 98 were so simple.
Roll Your Own Build Thread
Old 03-14-2017, 07:04 PM   #6
Oh yeah, just a year or two can make a huge difference
Old 03-16-2017, 02:04 PM   #7
Chassis: AmTran
Engine: International DT466E 7.6L inline 6
Ive got a 2000 I can try and snap a pic for ya
Brasquatch is offline   Reply With Quote
Old 03-17-2017, 09:31 AM   #8
Engine: T444e
Rated Cap: 35
That would be great. I have tracked and removed most of the school related wiring already, but knowing what fuses are what would be helpful.
Old 04-06-2017, 10:40 AM   #9
Chassis: AmTran
Oh man Im sorry I just saw your reply this morning, all my notifications were going to spam. Crazy rain here today, Ill get out later or tomorrow and snap a pic for you
Old 04-12-2017, 11:35 AM   #10
Brewerbob's Avatar
https://www.centralstatesbus.com/200...l/TC_start.htm
http://www.centralstatesbus.com/Manuals.html
Old 08-08-2018, 09:42 PM   #11
Help please!!!
I have the same bus! 1992 Amtran international genius. Can you send a picture of the whole fuse box Iím re wiring my bus for my new lights.
Quickbuffer is offline   Reply With Quote
