Old 03-12-2015, 07:46 PM   #1
Chassis: I.H.
Generator location
I was planning to mount my generator in a container welded together and mounted on the back bumper but my bed in just inside that back door. The gen is too tall for under the floor. Then I saw a bit of talk about putting one in the trailer. This is an interesting idea. It would be on the front of the trailer in one of those tongue boxes like this:
There would be ventilation tward the back of the trailer for air intake and exhaust and the box would be lined for sound. The cables would run to the bus. When the trailer is disconnected on occasion, the gen could be removed from the box and reconnected to the bus.
Anyone see an issue with this? Please chime in with input and experience.
Old 03-13-2015, 07:02 AM   #2
Chassis: I.H.
O.k. so I am going to take no response as it ain't been tried before.
My reasoning is multifold. I want to save space and not mount it on the back of the bus. I want it away from the bed at night to make it more quiet. I plan to pull a trailer anyway for the second vehicle.
Old 03-13-2015, 07:26 AM   #3
I mean, you can put it anywhere, and if this works for you, then go for it! I've seen guys around here put WAY crazier things on their trailers, and don't get me started on the off-road Jeep crowd.
If I have one concern it's the plan to pull the generator out and put it elsewhere sometimes. I don't know what generator you have, but those things are heavy as hell and not very well-balanced. I never dead-lift mine, and I'm strong enough to do it. Unless yours is some small, portable unit, I would realistically plan on not lifting it out of there very much...
taskswap is offline   Reply With Quote
Old 03-13-2015, 08:19 AM   #4
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
I plan to carry and run my generator (Hyundai 2000Watt) on my trailer. Just be careful and vent the heck out of that box, you don't want the generator to overheat.
Old 03-13-2015, 09:07 AM   #5
"The gen is too tall for under the floor. "
FWIW Here's our Onan BF with about 3in of space above it.
dond is offline   Reply With Quote
Old 03-13-2015, 02:38 PM   #6
Engine: 466DT
I've tried just about every spot with my 2800 boost inverter yamaha. The only place it will run going down the road is on my car trailer. It's just like Bansil said in the other thread about needle, seat, float... It never actually dies, but the inverter trips out and doesn't produce electricity.
My first try,
Untitled by Hvbuzz, on Flickr
Second, by far the worst place. Way to much bouncing around.
2012-06-26_12-19-38_364 by Hvbuzz, on Flickr
Trailer. It's right in front of the front bumper of the jeep. Even at the front of the trailer it wouldn't work right. Apparently the smooth spot is halfway between the hitch and the front axle of the trailer. I would play around with locations before making anything to permanent.
20140706_080548 by Hvbuzz, on Flickr
This year taking some steps back again. I bought a used old onan hoping it will run fine on my first spot, under the bus. I'm hoping its just not as particular as the fancy yamaha. I'll probably still bring the yamaha for when we are parked. It doesn't use much gas, and is amazingly quiet. 98% of the time I usually have the trailer in tow. However, there have been times I didn't want to take the trailer but still have a genny. So I guess I'm still battling the gen placement.
20150118_104708 by Hvbuzz, on Flickr
Dond,
How does your onan run going down the road there?
Hvbuzz is offline   Reply With Quote
Old 04-27-2016, 10:42 AM   #7
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Exclamation I'm in all kinds of old threads!
My first try,
Dond,
HvBuzz, love the idea of the brackets in the first picture!
I have a Ryoby 2200, which in dimensions at least should similarly compare to your yamaha. I haven't tried mounting and driving the bus anywhere, yet, to test as you said if the gen still outputs anything, but i did shake it a bit while it was running a few times, and nothing happened I will have to try, though...
I was planning on putting my gen unit in a "roughneck" type of container, vent it with holes on opposite sides, then run electrical to it using grommets and some silicon seal to make it as much weatherproof as possible.
The whole thing would be mounted under the bus, using a combination of steel plates and threaded rods.
Any thoughts? And hwo did it go with the used Onan?
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 04-27-2016, 11:25 AM   #8
Robin97396's Avatar
Holes in your tote are not enough to keep things cool. To put it simply I believe your tote would overheat the generator. Beyond the exhaust issue there is forced air that blows through the cooling fins on the cylinder head that usually also comes out near the exhaust port. That heat would be trapped and recirculated inside of your tote unless you hung the hot end of the genny out the back end of the tote.
Still, unless it's electric start you're going to get tired of dealing with that tote every time you want to start the genny or shut it down. Protection of genny, good. Difficulty with operating, bad.
Old 04-27-2016, 11:51 AM   #9
Coachwork: Ward
Couple of things i forgot to mention:
1. i was planning on piping the exhaust to the outside of the tote
2. possibly add PC fans to force air cirulation
Reading your reply ( BTW) got me thinking some more, specially due to the fact that if i position the gen the way i had originally planned, i would have to take it down and up every time i wanted to restart it....yeah, PITA
Soooooo....might instead mount the unit on the one of the center beams, pull-start handle out, no overall tote, but only cover the electrical panel with something....i don't really care if the main body of the genny gets dirty, i'm only concerned with the electrical panel shorting out if hit by spray, mud, etc...
Old 04-27-2016, 12:13 PM   #10
Coachwork: Ward
Something along these lines (no pun intended):
Does anyone else bother shielding something like the small Honda EU when mounted underbelly?
Sent from my Nexus 6 using Tapatalk
