Old 06-27-2017, 09:40 PM   #1
Generator Mounting
A friend of mine is converting a Thomas long nose with 444T into a rescue dog transporter. He wants to run 2 13.5K a/c's and maybe some lights. He has bought a 12K generator to power the bus. Dimensions are 40x30x23.
Does anyone have any ideas on how or where to mount the generator? He would like to leave the rear access door unblocked if possible.
Thanks in advance.
Bruce
BMWTX is offline   Reply With Quote
Old 06-27-2017, 09:45 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Thanks in advance.
Bruce
Under the bus? Cut the skirt and fab a box( ventilated) to hold it.
Old 06-27-2017, 09:48 PM   #3
That has been my first thought. Going to be a bear drilling that frame though.
Old 06-27-2017, 09:50 PM   #4
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
No need. Hang the box from the ribs that support the floor.
Old 06-27-2017, 09:56 PM   #5
Dog Rescuer's Avatar
Yeah for Dog Rescuing!
You can get a welder to put something under there relatively cheap. I was going to have one mounted on the in the back and add a vent to the side panel - I was also going to add a spot for another set of batteries to be mounted under the bus - there is ample room.
- Roger (Dog.Rescuer)
Dog Rescuer is offline   Reply With Quote
Old 06-27-2017, 09:59 PM   #6
turf's Avatar
my gen came factory but it hangs just behind the battery box.
Turfmobile Build Thread
Old 06-27-2017, 10:15 PM   #7
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Mine is same Coachbuilder as Turf- It is a heavy angle iron frame mounted directly to the frame- utilizes many existing holes.
The generator cage then has rollers that allow the genset to slide-out on c-channel for maintenance. Very slick system. Mounted directly in front of rear wheel to keep weight back.
