Old 12-02-2015, 07:43 PM   #1
Chassis: MVP SAF T LINER0
Engine: cat
Generator or solar
So we want to have a washer/dryer, A/C and fridge and lights
We want solar but afraid the amount of power I will need I would need alot of panels to run everything.
someguy is offline   Reply With Quote
Old 12-02-2015, 07:55 PM   #2
Running a dryer from anything other than straight a/c is going to be very difficult. Most are 220v, I have a small one that is 110v but they all require a lot of amps.
You can't really run any of that straight from the panels. maybe just the lights. You well need a large battery bank, with a solar charger. Then an inverter to convert the batteries to a/c voltage. A generator might also be necessary to run all that.
As far as how many panels depends on their amp out put, hoe big of battery pack, and how big of an inverter.
Start with the amp draw of your appliances, add them up and go from there
HTH
Eric
daddyoften is offline   Reply With Quote
Old 12-02-2015, 08:56 PM   #3
OMGIBoughtABus's Avatar
Chassis: Saf-T-Liner
Engine: Cat 3208
Rated Cap: 84 px
You have to be realistic about what you can run off of solar.
Here is the best source of information I have found on a solar setup. He speaks from actual experience.
https://handybobsolar.wordpress.com/
OMGIBoughtABus is offline   Reply With Quote
Old 12-02-2015, 09:39 PM   #4
Porque no los dos?
CaptainInsaneo is offline   Reply With Quote
Old 12-02-2015, 11:22 PM   #5
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
Ideally, both. Solar when it's good, generator when you need it.
Puggy is offline   Reply With Quote
Old 12-03-2015, 12:26 AM   #6
Roger what Puggy said!
Old 12-03-2015, 04:05 AM   #7
Coachwork: ward
Chassis: international
Engine: dt360a
ditto puggy. i can run whole bus on solar without air conditioning or heaters. consider the dryer as a heater. lights, tv computers, fans, coffee pot (short term) microwave 700w (short term) and fridge and frezer are no problem unless more than 1 day cloudy sky. then generator runs them while charging battery pak.
anything that heats is min of 1500w and will kill the batteries in short order.
Old 12-03-2015, 09:13 AM   #8
Chassis: B3800 Short bus
What about a gas dryer? Many people around here have natural gas dryers which only require 120vac electricity for the tumbler motor and the electronics. They should be able to run off of propane by swapping the nozzles (like other natural gas/propane appliances). You'd need a dandy of a propane tank, though.
