Originally Posted by TrailLifeBill
Can you post make/model of one that would have the above capabilities?? Sounds interesting.
Most brands(carrier,thermoking, etc.) out there are customizable and tailored to a buyers needs. I bought mine used and will really only use the 12v 120v options (already have a rooftop ac, no need for heat).
As far as links go, you can look at this one. 60 amps 12 volt, 5.2kw @ 120 volt, 12k btu ac, 10k btu heat.
https://www.carrier.com/truck-traile...ry-power-unit/
FYI cost on a new apu will be more then what you paid for the bus. I bought a pair of them for 100 bucks, with the hopes to combine them both into a functional unit.
