Old 03-09-2009, 09:26 PM   #1
Year: 1994
Chassis: Blue Bird
Engine: International
Rated Cap: 27
got a solar question
never used solar before, so how much would 2- 6 watt solar panels be able to power, and how beneficial would it be to my battery. For a party bus more than anything, my battery can only go so far, so about how much would an extra 12 watts be able to power, and for how long.
anyones guess is better than mine
nolan m is offline   Reply With Quote
Old 03-10-2009, 01:14 AM   #2
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Re: got a solar question
Relatively speaking, not much. Consider that a 60-watt light bulb uses roughly 5x what those panels could produce in full sun.
Look at the power usage info that is present on every electrical appliance, tool or gadget to see what normal wattages are.
There are lots of threads here about power usage, solar power and batteries. The search function is your friend.
Good luck
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 03-12-2009, 12:12 PM   #3
Lady Franklin's Avatar
Engine: 7.3 International Diesel
Buy this book
RVers' Guide to SOLAR BATTERY CHARGING by Noel and Barbara Kirkby ISBN # 0-937948-08-X
This will tell you all you need to know on Solar Powering your rolling home.
Lady Franklin is offline   Reply With Quote
Old 03-12-2009, 02:56 PM   #4
lapeer20m's Avatar
another issue is that most parties happen at night, which would render your solar panels pretty much useless.
just fyi, volts x amps = watts. so a 120 volt tv that uses 2 amps would consume 240 watts. (120 x 2 = 240)
Those solar panels you speak of may be good to trickle charge batteries if the bus were parked for extended periods of time with zero electrical loads.
Old 03-12-2009, 03:36 PM   #5
Year: 1994
Chassis: Blue Bird
Rated Cap: 27
well then for the parties i guess its pretty useless, but as for charging my battery, it would help, because it does sit for long periods of time, and everytime it needs to be moved, we have to jump start it, so it may help at least a little after all. thanks
Old 03-12-2009, 08:13 PM   #6
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
My first bus also needed jumping often. I'm positive it had a small phantom load, or a bad circuit. I think you would probably do well to also install a battery cut-off switch. Might help with the need to jump. Also a good theft deterrent! Just make sure to direct wire the solar panel, if used, i.e. so the cut-off doesn't also disconnect the panel!! Discharging your start batteries is very bad for them.
If it isn't grown, it has to be mined
http://weathersticker.wunderground.c...Winnemucca.gif
elkoskoolie is offline   Reply With Quote
Solar ovens and solar water heaters/showers tomas_maly Heating, Cooling and Appliances 6 05-22-2013 12:43 PM
SOLAR chev49 Conversion General Discussions 1 12-13-2012 12:07 PM
Solar panel question Stuff Everything Else | General Skoolie Discussions 1 12-11-2012 08:13 PM
Solar?? KKGREENBIRD Conversion General Discussions 0 08-11-2010 01:02 AM
Solar system question deadhead Conversion General Discussions 26 04-17-2007 10:05 PM
