Originally Posted by w8one
Ground definitely yes.
Bonding AC Neutral (household white wire) to ground NO.
i sifted through some results. i need to referwnce.my.manuals again. but as far as i can tell, the green ground screw shouldnt be in. im not an eletrician, but i go with all the results. mine is set up like this;
50amp (dual 50amp 180 degrees out of phase)
full sub panel, ground bar and nuetral bar separate.
i have it on a dual gfci breaker.
the breaker does pop correctly, it has popped before, ie worked correctly.
i do not have the ground screw in the sub panel. im relying on the shore ground, which i have inspected and it is indeed wired and grounded properly.
i used a few resources. i have a few electricricians books that i referenced when i did mine along with search reaults and this web site;
http://www.myrv.us/electric/
https://duckduckgo.com/?q=sub+panel+...&t=fpas&ia=web
edit; this thread is about just sub panels;
http://www.contractortalk.com/f5/und.../topics/109377
forums are not always sooper reliable, but i tend to go where i see concensus over multiple results. the sub panel should not be bonded. ie; the green screw gets removed according to the results. i prefer electrician manuals myself.
