03-23-2018, 07:15 PM
Has anyone tried running a mini-split on an inverter generator?
Hey Everyone,
I know that the inverter type generators such as the Honda EU2000i are quite popular and I have seen several members installing the Pioneer mini-split's.
Has anyone here run their mini-split from one of the inverter style generators?
I was reading something about the Honda having issues with certain types of loads. I don't recall what they were trying to run. It was something odd. A contractor style generator would run it but the Honda freeked out.
It occurred to me that the electronics in the mini-split are a whole lot different than your typical roof a/c and I should probably verify that they will play together before spending the $$
Thanks.
S.
03-23-2018, 07:27 PM
Chassis: AARE
Engine: 3116 Cat 250hp
I have a Champion inverter generator and can run a mini split.
03-23-2018, 09:21 PM
Chassis: Thomas
Engine: CAT 3126
I have a champion 3100/2800 inverter and it runs my 2x 1 ton mini splits easily.
03-24-2018, 07:52 AM
I havent had any issues with a honda running electronics... havent run a mini split but i have run the Climax portable unit which is a mini-split inverter style compressor in a portable unit package and it runs just fine, phone chargers, macbook pro chargers and even an APC sine-wave battery back-up (testing running a server rack) all run fine on. the eu2000i,
I havent tried running any high-load compressor items like a regular A/C, frig, or a high-start-current motor like a shop-vac etc on it..
03-24-2018, 09:52 AM
Thanks for the input.
Looks like I have nothing to worry about.
03-24-2018, 10:16 AM
I load tested my Honda 3000 (inverter) genny with my 8000 btu window unit. The A/C ran full blast without the Honda ever coming off "Economy Idle".
03-24-2018, 10:30 AM
I have run roof a/c's from a Honda EU3000i with no issue. The inverter mini-splits are a little different animal and I wanted to check with the community before I start spending $$.
Thanks again.
03-24-2018, 10:43 AM
Maybe someone else can chime in, but my understanding of the mini-splits is that they have a much lower start-up load and also draw less juice when running than conventional units. Cadillac can probably tell you more.
03-24-2018, 11:10 AM
I am of the same understanding. That is on of the reasons I am going mini-split and not roof air.
03-24-2018, 12:06 PM
Chassis: Thomas
Engine: CAT 3126
I have real time monitored my wattage draw with my 12000 btu pioneers. It creeps up from zero over a couple minutes. I’ve never really seen them go past about 2000 W total with both units running. I think they are spec’d to draw up to 1200 per unit but I haven’t seen it. Maybe that’s when you hit the turbo button.
Once the initial heat or cool target is reached it seems like they level out to about 650 W each or 1300 total. Depends on weather etc.
I’ve run 1 off my inverter while driving without trouble.
03-24-2018, 12:09 PM
Good info...thanks for sharing.
03-24-2018, 01:00 PM
The issue you speak of for the Honda, is that the neutral and ground are isolated. Contractor generators and the commercial system, they are not. The fix is to make a jumper out of a plug to connect the neutral and ground at the generator. Make sure not to jump the wrong terminal, it would be detrimental to your system.
I learned this from a book on RV wiring and how to NOT electrocute yourself with metal skinned campers.
Sent from my Moto Z (2) using Tapatalk
03-24-2018, 01:17 PM
Awesome information!
Thank you for sharing that.
