08-19-2019, 03:38 PM
#21
08-19-2019, 04:24 PM
#22
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by Iceni John
If you use sealed-beam lights, at least run them through relays to assure they get full voltage, and make sure they are properly aimed to minimize scatter and glare. One easy way to know if your lights will dazzle other drivers is to crouch down in front of them and see exactly where their vertical cutoff is - it should always be lower than a typical car's driver head height.
I drive up to within a few feet of a wall and turn on the lights - then I align them straight ahead and adjust them for up and down - it doesn't work as well as a shop with precision equipment, but on a good day, I come close
08-20-2019, 12:00 PM
#23
Originally Posted by o1marc
Those are the same basic ones i posted on post 11. They work great. on low beam they have a nice low pattern that angles up on the right for road signs.
with nice sharp cut off.
On high it all down the road. like high beams should be.
I run Sylvania silver star bulbs and they work quite well.
These will Need to be adjusted correctly.
08-20-2019, 01:17 PM
#24
Sound like a fair deal till you realize they don't come with bulbs. They are not sealed beams as advertised.
08-20-2019, 02:14 PM
#25
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Better than sealed beams as most of the time you can remove the H4 or whatever bulb they take without removing the entire headlamp, thus eliminating alignment checking...
08-20-2019, 05:50 PM
#26
this is the set im using on my DEV bus now..
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
they light up the road nicely and have a definite cutoff pattern..
08-20-2019, 06:00 PM
#27
I have 4 of those but in a 7" round light. Planned on 2 of them on the front for driving lights and 2 in the rear for back up. But they have so many lights in them I'm not sure they are good for much more than driving lights.
08-20-2019, 06:11 PM
#28
marc these arent the multi-row 15 LED lights.. that what I HAD previously. and those were only good for driving floods at best... THESE have a very definite pattern on the street as well as a cutoff.. they can be focused nicely.. the high beams are pretty damn bright too and of course they sail the light much farther and wider as well..
the low beams are easy to focus mainly in your lane with a bit of low spread-off for seeing animals or objects alongside the road and not blind other drivers..
08-21-2019, 04:34 PM
#29
Buy quality DOT approved LEDs. I’dGuess most of the non DOT LEDS ARE FOR
OFF ROAD. - read the fine print.
Lots of quality LEDs on Amazon- but don’t buy the first ones you see. Take the time and research them.
I just bought 5x7’s DOT approved for $85.
08-21-2019, 05:05 PM
#30
Chassis: bluebird intl 3800
Engine: t444e
Rated Cap: 7.3l
Beamshots of aforementioned cheap leds from Amazon
Full-timer here. Use amazon for fast shipping as we usually don't know where we'll be in a week. Replaced the stock incandescents with the standard $40 cheap leds last October. Definitely an improvement and worth the $ imo
Reused the rusted housing scraps (flakes?) thx to some pb blaster.
08-21-2019, 05:30 PM
#31
Daniel Stern and Susquehanna Motorsports (rallylights.com) are both excellent sources of high quality parts AND advice. I’ve used both in the past, and they are my go-to sources for all things lighting. Absolutely top-notch vendors.
08-22-2019, 01:05 PM
#32
Truck-lites are one of the best on the market for LED headlamps. Yes they are a little bit pricey, but you pay for quality. They come heated (for snow climates) or non-heated. Coming from the Jeep community, I have used these in the past and throw an amazing amount of light but are not super blinding. High quality company enough that one of our local trash companies swapped out all their garbage trucks with the heated versions.
Truck-lite dot com
08-22-2019, 01:52 PM
#33
Would these be drop-in replacements for the headlights in my bus, or would have I to finagle them a bit to get them to fit? I don't feel like dealing with my light situation yet (one is out and half-flooded and the other gives off pretty much a candle glow) but that's limiting me to daytime driving only right now.
01-30-2021, 04:05 PM
#35
Chassis: chevy
Engine: 3116 catapillar
i will not replace my incandescent lites with leds as i have them on my truck and they suck. they freeze over in as little as 10 minutes and i pull my truck over on a ramp to clean them too often
01-30-2021, 04:13 PM
#36
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Originally Posted by mmoore6856
Attachment 53543i will not replace my incandescent lites with leds as i have them on my truck and they suck. they freeze over in as little as 10 minutes and i pull my truck over on a ramp to clean them too often
I'm not trying to talk you into LEDs...but if you like them, except for the freezing issue, you should check out the Truck-Lite headlights...they have heated versions which are really good quality and stay ice/snow free. Yes, I'm in Arizona, but were I am in the mountains we do get snow. We've had about 3 feet in the past week. I put Truck-Lite headlights in a FL60 and love them. Having said that, I'm not an LED fanatic. I find that regular incandescent spots, like the old-school KCs let me see better than those fancy LED bars and all...I just don't seem to have the same depth perception or something with LED light. But the Truck-Lites are head and shoulders better than the stock headlamps which came on our FL60.
01-30-2021, 06:31 PM
#37
Chassis: chevy
Led headlamps also do not reflect in the eyes of deer and other critters. I hit them too often so now i run a full sized front gaurd
02-03-2021, 06:41 PM
#38
Engine: Cummins 8.3
I have been using Hella E-code lights H-1 and H-4 for 30+ years and think you can't get better lighting. Some of mine have been through 4-5 cars / trucks. I always use relays. I also have a pair of Hella rally 1000's on the bus now for spot beams like KC's. I can watch the deer and the antelope play a half mile away. My newer cars with the plastic crap lights work good for about 2-3 years and the NM sun turns them yellow and cloudy. Just my .02
02-14-2021, 07:35 PM
#39
I pulled off my crossover mirrors on our 5 window Chevy e3500 and plan on mounting something like the Hella rally 1000 on each side of the motor using the existing mounts.
Not a fan of night driving (mainly because of deer 🦌 and also missing the entire countryside) but having some powerful lights would make it more tolerable.
I remember driving a new Prius with new LED lights across Montana and the lights were freaking bright on hi beams. Compared to my car at least.
Bulbs also get dimmer over time right? So even just replacing with newer brighter may help? It's not like we drive as many miles as commercial drivers
02-15-2021, 10:43 AM
#40
These are the ones that I bought from Amazon also DOT stamp right on them. They were $85.00 .
I value Cadillac Kids opinions and he is happy with his LED lights so I think I will be happy with them also. Or, more importantly, other drivers will be happy also and not blinded. I replaced every single fixture with DOT except the two side marker turn signals on each side and I put LEDs in them also. Added a dozen more side marker lights and they are stamped DOT too. Am going to add a set of Ridgid DOT foglights as soon as our Tax refund hits Woo Hoo.
Also plan to install zombie lights on 4 corners of my bus but since they will not be used on the highway am not concerned about DOT ratings. Just want to be able to melt Zombies with the toggling of a switch.
