Old 04-21-2019, 06:13 AM   #21
Good work and find on the DLR module JBird. Such corrosion for being inside the bus. Glad you got rid of that electronic gremlin.
I thought that wasn't part of the headlight circuit but know differently now.
Should be cheap to replace if necessary.
Old 04-21-2019, 06:16 AM   #22
Ha! I win!
Old 04-21-2019, 06:21 AM   #23
Ha! I win!
CB, the gremlin guru for 420 2019...great call bud!
Old 04-21-2019, 08:27 AM   #24
That's funny!
Old 04-21-2019, 10:57 AM   #25
Rovobay's Avatar
Rated Cap: 35
Originally Posted by JBird152 View Post
It was in the lower panel by the left foot, when seated in the driver's seat. I was able to follow the bundle down from the steering column and locate it that way.
Here is the module and it looks like corrosion was the culprit. I'm glad that bug is out of the system now. Back to the build...
So you were able to just disconnect and it solved the problem? I would like to disable my Daytime running lights. (I like running with just the parking lights for the cool buy affect, plus for photos!) Glad you got it figured out.
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 04-26-2019, 04:14 AM   #26
Engine: DT 466E
Rated Cap: 30,000
Yes. It was a simple fix once I figured out what I was looking for....
Pulled the module completely out of the system and threw it in the trash, so turning markers/headlights on is a manual operation now.
JBird152 is offline   Reply With Quote
Old 04-26-2019, 06:19 AM   #27
Ciscokid's Avatar
Coachwork: Me
Chassis: 2001 IC
lights
This is a awesome teamwork guys!! I have this same exact issue and will be looking into this module this weekend to do the same. I thought my bus was haunted. on off on off on on off
Ciscokid is offline   Reply With Quote
Old 04-29-2019, 06:05 PM   #28
Pull apart the connection from body to hood.
