Old 04-19-2019, 11:27 PM   #1
Engine: DT 466E
Rated Cap: 30,000
Headlights stay on all the time. 1998 International/Thomas 3800
My headlights stay on all the time now. A while back, the headlights would flicker or turn on at random (while parked-ignition switch off).
I now have to disconnect the battery cable to kill the lights. I'm assuming a relay has gone bad somewhere, but I don't know which relay to check.
Does anyone have a wiring diagram and/or recommendations on where to start looking?
JBird152 is offline   Reply With Quote
Old 04-20-2019, 01:08 AM   #2
Chassis: IH
I can't remember if there is a relay, or the power just goes through the switch. Also, does your bus have automatic daytime headlights? That module could be responsible too. Mine has/had the ADRL (I pulled the fuse for it).
Old 04-20-2019, 02:00 AM   #3
Engine: DT 466E
Rated Cap: 30,000
Yes, it has either the ADRL or just a constant on when you turn the ignition switch to run (not sure if there is a difference).
Where would I find the module and the fuse? Do you have a pic of the fuse panel schematic?
I pulled the connectors off the back of the ignition switch and the lights stayed on. I pulled the connectors off of the headlight switch and the lights stayed on.
The headlight switch is the push-pull type with dimmer.
Old 04-20-2019, 09:02 AM   #4
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
I really think it is a relay somewhere, but I can't tell you where...
Old 04-20-2019, 09:45 AM   #5
A faulty dimmer will cause this condition. pretty sure no relay is involved in headlight circuitry.
Not an easy fix if dimmer is on the steering wheel.
Good luck.
Old 04-20-2019, 10:11 AM   #6
Rated Cap: 26 foot
The daytime running lights in my bus use a relay, methinks.... But mine's a BlueBird.
Old 04-20-2019, 10:40 AM   #7
Chassis: IH
My IH/BlueBird has a similar headlight switch. The ignition switch isn't (as far as I am aware) tied to the headlights, but the fact that you disconnected the headlight switch and still had lights helps me a lot.
I'm not sure where the ADRL module is but I remember there was a fuse for mine (which I pulled). I'd like to remove my ADRL module, since pulling the fuse seems to have caused my parking brake indicator to stop working (the bulb has been checked and replaced). I'm not sure where it is, though, or what it looks like. Anyone?
The dimmer has to be getting voltage from somewhere. If the headlight switch is off, then I'm not sure where it would be getting voltage from.
Uses a relay, likely, but where's the ADRL module? I'd like to remove mine and restore function to the parking brake light.
Old 04-20-2019, 12:11 PM   #8
Good luck.
So there is no misunderstanding, my wording wasn't the best, sorry.
I had said dimmer switch when in reality it should be the hi-lo beam selector switch. Can be on the floor or steering column that is why I mentioned it is a tough job on the column.
Gnomer, hear ya on the DLR's but think the circuits aren't connected at all off the top of my head, no diagram to prove it unless someone else can post one.
Happy 420
Old 04-20-2019, 12:24 PM   #9
A thomas I'm looking after did that. The DRL module was bad. Disconnected it.
Old 04-20-2019, 12:26 PM   #10
Engine: DT 466E
Rated Cap: 30,000
Happy 420
John,
Thanks for the clarification. The hi-lo selector is on the column. The selector switch still turns the high beams on and off.
Are you saying that the switch may have failed on the low side and could be causing the issue?
Old 04-20-2019, 12:28 PM   #11
Engine: DT 466E
Rated Cap: 30,000
Where is the DRL module located?
Old 04-20-2019, 12:35 PM   #12
John,
Exactly JBird. Two sections to the switch, one does the beam selection.
To prove it disconnect battery. Test each side thru the connector for continuity from the selector switch when you move it.
Hope this helps, I just forgot what your problem is,
Old 04-20-2019, 12:49 PM   #13
I can't recall. Its in the electrical panel. I found it using google.
Old 04-20-2019, 10:03 PM   #14
Engine: DT 466E
Rated Cap: 30,000
I pulled both of the connectors off of the hi-lo/turn indicator switches on the column and the headlights are still on.
Old 04-20-2019, 10:07 PM   #15
Chassis: IH
At this point I'm reasonably sure you've got a problem with the ADRL module/relay(s). There's a fuse for it (and I don't remember which one it was) that you can remove to disable it. I want to say it was an unmarked fuse to the left in the fusebox.
Old 04-20-2019, 10:17 PM   #16
Engine: DT 466E
Rated Cap: 30,000
Many thanks. We know what it isn't... We shall keep digging.
Old 04-20-2019, 10:58 PM   #17
Engine: DT 466E
Rated Cap: 30,000
Success!
I was able to locate the DRL module and remove it. Headlights function how they are supposed to now.
Many thanks to everyone for the brainstorming and troubleshooting!
Old 04-20-2019, 11:12 PM   #18
Chassis: IH
Success!
Excellent. Where was it and what did it look like?
Old 04-20-2019, 11:38 PM   #19
Engine: DT 466E
Rated Cap: 30,000
It was in the lower panel by the left foot, when seated in the driver's seat. I was able to follow the bundle down from the steering column and locate it that way.
Here is the module and it looks like corrosion was the culprit. I'm glad that bug is out of the system now. Back to the build...
Old 04-20-2019, 11:45 PM   #20
Engine: DT 466E
Rated Cap: 30,000
That switch was by far the cleanest part that I have seen on this bus! The guys at the bus barn must have replaced it not too long ago.
Thanks for pointing me in the right direction
