Old 11-24-2017, 07:37 AM   #1
help
I just bought a 1989 Ford Bluebird school bus. Someone stole the batteries out of it and cut all the wires. I don't know how to hook the wires up. 12 or 24 volt ? Series or parallel ? Someone please heip. It has the Ford desiel engine in front, 72 passenger. Thanks
Big John is offline   Reply With Quote
Old 11-24-2017, 07:45 AM   #2
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
12 volt so if you use 2 batteries that are 12 volt parallel is what you want
mmoore6856 is offline   Reply With Quote
Old 11-24-2017, 07:45 AM   #3
ziggy's Avatar
Rated Cap: 11
Wow, that is AWFUL. I'm so sorry.
Sent from my Pixel XL using Tapatalk
ziggy is offline   Reply With Quote
Old 12-08-2017, 08:01 PM   #4
golfersmurf57's Avatar
Probably 12V but clean the case on the alternator and it will probably be stamped on the case. Of its 12 its parallel 24 is series or it will have a big solenoid near the battery case sometimes in it with the series/parallel relay in it. Will have 4 of the cable connections and 2 control small wires on the relay. These units start on 24 and charge on 12. Yours is most likely 12 cranking and charging. And unless its a white motor co chassis or a Mack, its neg ground
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 12-09-2017, 11:46 AM   #5
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
You know what would help & I've said this before,, Finish filling out your profile so members can see where your located that way if someone is close by & if their willing could offer to help.
Old 02-04-2018, 11:28 PM   #6
For Stu and filo? I can't get into mine to finish or edit. Doh!
