Old 04-28-2019, 04:20 PM   #1
RLVmann's Avatar
Coachwork: Crown by Carpenter
Chassis: Spartan
Help with emergency door starter disable
Trying to remove wiring from rear exit. Not sure how to accomplish this. Can't fine any info about my setup. 1998 Crown by Carpenter bus. FE. Please advise?
IMG_20190428_153903.jpg   00000PORTRAIT_00000_BURST20190428153945812.jpg   IMG_20190428_154015.jpg   IMG_20190428_154020.jpg   IMG_20190428_155059.jpg
RLVmann is offline   Reply With Quote
Old 04-28-2019, 04:24 PM   #2
Wow, I wish my wires were marked like that, mine are just numbered. Should be easy to determine which wires to delete when they have their name o them.
Old 04-28-2019, 06:27 PM   #3
RLVmann's Avatar
Chassis: Spartan
It is nice but only helpful if I can figure out how to bypass.
Old 04-28-2019, 06:31 PM   #4
I can only help you at the door. When I deleted mine I had to keep the ground wire connected. I did not go forward and delete relays or anything.
Old 04-28-2019, 06:38 PM   #5
RLVmann's Avatar
Chassis: Spartan
So if I just ground the starter solenoid wire to the frame?
Old 04-30-2019, 06:29 AM   #6
RLVmann's Avatar
Chassis: Spartan
No electricial gurus able to shed some light for me
Old 04-30-2019, 09:52 AM   #7
ermracing's Avatar
Engine: DT466E (195hp, 520tq)
Check what the switch does with an ohm meter. Does it close the contacts when the door is open or closed? Then either connect the wires or not, depending on the situation.
Dave
Old 04-30-2019, 10:17 AM   #8
RLVmann's Avatar
Chassis: Spartan
thank you I will try that
