Old 12-20-2016, 09:05 PM   #1
Hi! I am new here with A new Bus!
Hello, Fellow Skoolie owners! I just purchased my 2003 E-450 7.3L about a month ago. I just purchased 8, 150W Solar Panels. I was looking on amazon and the mounting brackets are almost the same price I paid for the panels!"65$" per panel...45$mount?
It does have a curved roof so I was wondering if you guys would have a better/cheaper way of mounting them so they can tilt during the winter with less expensive mount or by making a Rack for them?
I looked around for older posts but I cant find what I need.
Thanks in advance
Melo1111 is offline   Reply With Quote
Old 12-20-2016, 09:16 PM   #2
Rated Cap: 65 pax
Thanks in advance
Welcome! What are you planning on doing with the bus?
Sandi
WanderWoman is offline   Reply With Quote
Old 12-20-2016, 09:20 PM   #3
I plan on camping in it and road trips I just wanted to have the extra panels for extended camping trips and staying in it on my friends property for a few months
Old 12-20-2016, 10:31 PM   #4
Carytowncat's Avatar
Welcome Mello, glad you are here.
To my surprise i mounted my panels flat and have not had a problem with the sun being so low in the sky, and i only have 2 up there.
I think i read here... or somewhere that the tilting only provides a small amount of extra in winter.
Congrats on the bus
Old 12-20-2016, 10:39 PM   #5
I was wondering what brackets I can use? I have seen people just use some adhesive and not have to drill into the roof?
Old 12-20-2016, 11:24 PM   #6
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
I haven't sat down to work out the details yet but Iceni John fabricated mounts for his panels and I want to do something similar.... they mount to a rail near the center of the roof (I think he left a 12 inch walkway between his roof hatches) and fastened them down with hinges on that side and has the other side rigged where they can be down against the roof for travel (20 degrees off horizontal I think), or he can raise them to be flat, or angled up at 33 or 45 degrees.... don't remember the lesser angle but full up is 45. Search around in the solar section for the post, I think that's where it is now.
Old 12-21-2016, 05:39 AM   #7
Chassis: 3800 Carpenter
Engine: DT360 / AT545
Rated Cap: 65 passenger
And please let us know what you end up doing. Lots of pictures help. This is the most detailed option I've seen:
http://www.skoolie.net/forums/f13/di...tem-13553.html
oredigger is offline   Reply With Quote
Old 12-21-2016, 08:17 AM   #8
Engine: Navistar 7.6L
just use pivot points on the lower edge of panels.
then a rod or two per panel that holds the panels at the desired angle.
Something like this where you lift panel and the tighten the friction part to hold it.
DoubleO7 is offline   Reply With Quote
Old 12-21-2016, 02:21 PM   #9
Thanks guys! I am still not sure what screws to use, drilling holes for 8 panels seems like a lot of holes and chances of the roof leeking and if I need to have nuts holding it down on the inside?
Old 12-21-2016, 02:48 PM   #10
rossfree's Avatar
Coachwork: Chevy
Chassis: Ward?
Engine: 8.2 liter ?
Rated Cap: 24 Passenger
Congrats on the bus
I agree with "town cat". You have enough to do with your new bus without worrying with tilting them for more energy. Flat will be good enough... certainly for now. I have 480 watts charging four six volt golf cart style batteries. Nice and flat. Works great.
You can always work out tilting mechanisms later if you think you need it. I doubt you will. Don't mount anything around them that will shadow them. Nothing. Even the smallest shadows will significantly reduce your output.
Welcome aboard!
Ross
rossfree is offline   Reply With Quote
