Old 04-25-2019, 02:55 PM   #1
Engine: International t444e
Rated Cap: 66?
Horn not working
Hey everyone
I have a 98 International 3800 with the t444e.
The horn doesn't work, although the relay clicks when I engage the steering wheel switch. The horn does work when I run a jumper from the battery.
Does anyone know how the horn is wired? Is there a fuse somewhere between the relay and the horn that I should know about?
Thanks in advance - Gary
ghodges is offline   Reply With Quote
Old 04-25-2019, 04:56 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Sounds like it's just a fuse?
Look in your fuse panels and try to spot any that are blown?
Most likely a 10-15 amp one.
Good luck
Old 04-26-2019, 11:55 AM   #3
Rated Cap: 66?
Thanks man. That was my first thought, but the horn fuse was solid.
Also, since the relay is clicking, it would seem there is power to that point.
So now I'm wondering if there might be an inline fuse somewhere or if I have a break in the wire.
Old 04-26-2019, 12:03 PM   #4
Ciscokid's Avatar
Coachwork: Me
Chassis: 2001 IC
My horn is located right under the bus under driver seat. stick a volt meter on it and start tracing it backwards.
I want the train horns that flying J sells
Inside your electrical door on the side is there a wiring diagram? like this one?
Ciscokid is offline   Reply With Quote
Old 04-26-2019, 01:35 PM   #5
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
What, horn doesn't work? That blows... lol couldn't resist.
Old 04-26-2019, 02:31 PM   #6
Swap the horn relay for another similar one. Or check the ground on the relay socket itself. Pushing the horn button completes the circuit to ground and that makes the horn blow if the relay is good.
Could be a broken wire running up the steering column to the horn button.
Check everything with a meter, don't be guessing.
You checked the horn already so that much works, only leaves the relay or harness.
BlackJohn is online now   Reply With Quote
Old 04-26-2019, 02:54 PM   #7
Rated Cap: 66?
Yeah Cicso - My horns are located right under the radiator so tracing the wires back through the engine compartment is a bear, but that may be what I need to do.
I don't have a wiring diagram in the main compartment, but I do have the owner's manual, so I could check in there.
This might be my excuse to go ahead and get an air horn!
Old 04-26-2019, 03:01 PM   #8
Rated Cap: 66?
atleast10characters
Old 04-26-2019, 03:03 PM   #9
Rated Cap: 66?
I do have a spare relay, so I can try that. The switch does work. I'm guessing there is a problem in the harness. Joy, joy. Thanks
Old 07-20-2019, 07:36 PM   #10
TeacherJoe's Avatar
Engine: Cat C7
Iíll dig up this older thread...
My horn doesnít work either. I honestly canít say if it ever did. Itís on Ď05 Thomas FS65 with no relay. Just a fuse. With the ignition on, I read no power at the horn button wires, no power at the fuse, and no power at either connector at the the horn. There are two connectors and one horn.
Do I just need to install a new aftermarket unit?
Joe
Follow on Instagram @a_bus_named_sandy
TeacherJoe is offline   Reply With Quote
electrical, horn, international 3800
