Old 07-24-2018, 09:20 PM   #1
Chassis: MVP RE
Hour Meter Problems
Does any one know how to trouble shoot an hour meter on a Thomas MVP ER bus? Mine is not working and has never worked.
budbud7 is offline   Reply With Quote
Old 08-03-2018, 02:44 PM   #2
golfersmurf57's Avatar
Most are just mechanical with a electric winder. On back side if its two wires it will be marked + and -.
If digital + and minus come on with key and third wire comes on to log hours. If these are present replace it. If not then trace to find what's missing. Log wire usually comes from ing coil pos. Or if its driven miles the through a diode block from trans position switch. And its possible its for hours on a wheel chair lift.
golfersmurf57 is offline   Reply With Quote
