Old 01-23-2019, 01:38 AM   #1
Chassis: MD463
How much power do you use?
I am getting ready to buy my solar system and am wondering how much power people use on average per day. I have some pretty high demands as an entrepreneur using two computers that run 24/7, house fridge, sewing machine and lights.
I want to be able to go a 3-5 days with out charging, so i am trying to figure out how big of a battery bank and inverter I need.
Thank you!
yaakbus is offline   Reply With Quote
Old 01-23-2019, 06:51 AM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
The answers will be all over the place because everyone and every setup is different. A meter such as this Kill-A-Watt is a very useful tool for measuring your own power consumption. You connect it to each of these devices, run it for a few days, and then you know exactly what it consumes. You can then size your system using empirical data rather than guesses.
JD - Full timer out west
My Adventures & Build
Old 01-23-2019, 07:36 AM   #3
Chassis: MD463
I need a minimum of 4800 Watts daily, I was just curious what other people use.
Old 01-23-2019, 11:20 AM   #4
Yaakbus,
Have you calculated the battery bank that you are going to need to support 4.8kwh daily with a 3-5 reserve?
For a mobile application that is huge!
4800watts * 5 days = 24,0000 watts of usable battery bank. For any kind of reasonable battery life you want to avoid discharging beyond 50% DOD. So..... You will need a battery with 48,000 watts of battery capacity.
So.... A 48 volt / 1000 Amp hour battery bank would work. Now size the solar array that you need to support that.... Keep in mind that you want a C/8-C/12 charge rate. You will need roughly 83 amps available to charge with.
To provide 83 amps at 48 volts you will need, in a perfect world, 2000 watts of solar. Realistically closer to 2500watts minimum.
Perhaps you may be well served by looking at ways to reduce your power needs and reconsider your 3-5 day autonomy.
What you have described would be a reasonable system expectation for a fixed installation but being mobile we have to compromise.
PNW_Steve is online now   Reply With Quote
Old 01-23-2019, 11:26 AM   #5
Just got a Kill-A-Watt yesterday and plugged my kitchen fridge in it. I just checked and after 24.5 hours it has used 1.09kwh. How does that equate to need on the system.
I'll plug my laptop in and see what it uses. there's something wrong with the Mac, it has an 80% charge on the battery and must be plugged into the charger or it dischages and doesn't recharge, so I have to have it on the cord all the time..
o1marc is online now   Reply With Quote
Old 01-23-2019, 11:26 AM   #6
I guess that I didn't give a direct answer to your question.
I use about 1.8 kwh daily.
I have a residential refrigerator that runs from the battery bank but I start the generator in the morning to run the coffee maker and hair dryer.
Old 01-23-2019, 11:32 AM   #7
Chassis: MD463
Yeah I have calculated it all out. The average home uses between 13-30kwh per day and was just curious as to what peoples average use in their bus was. It was more just a question about how much power people used, rather then how to calculate a system. That part is easy.
Old 01-23-2019, 11:37 AM   #8
Chassis: MD463
If you have a kwH and you fridge is using more than that, your system is too small. As far as I have been able to learn through this is, most people use less then 3kwH per day so 600ah battery bank is plenty.
You need to have twice the amount of storage then you have discharge for a healthy system. So you at a minimum need a 2000 watt inverter for a computer and fridge (it that is all you use it for) and 400ah of battery so you dont discharge past the 50% recommendation.
Beyond that, I would say your mac has an issue with the Battery if its not charging.
Old 01-23-2019, 11:38 AM   #9
Chassis: MD463
Awesome, that is good info to know. Do you have a 2000 watt inverter? 400ah battery bank?
Old 01-23-2019, 11:42 AM   #10
It's not a battery issue. Battery, charge port, charger and screen are all brand new.My brother, the computer expert, says it's an intermittent problem on the logic board.
My inverter is a 3000/6000 pure sine. I'm trying to make the system with the most power output with the least amount of batteries so I don't end up with $4k worth of batteries. Looks like my home uses 40kwh a day on average.
electrical, power, solar system
