Old 05-21-2018, 10:01 PM   #1
How reliable are my charge controllers 'State of Charge' Indicators?
Hi everyone,
We've just had our solar system set up, however I am running into an interesting situation.
We are plugged in to shore power all night right now which is charging our batts to basically full. Then we have had direct sunlight all day (unplugged).
Our Tri-star PWM 45 amp controller flashes green and the manual indicates that means we are at 80-95% SOC (state of charge)
However, within maybe a few hours of the sun going down the charge controller is indicating 0-35% state of charge.
Has anyone experienced this? I'm struggling to find information online.
Jeremyc is offline   Reply With Quote
Old 05-22-2018, 08:35 AM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Anything that uses voltage to indicate SOC for a battery that is in use is a waste of time.
The only time that voltage is an approximate indication of SOC is after the battery has been resting for many hours.
A good battery monitor is a very useful tool. These use a shunt to measure all electrons flowing into/out of the battery and, based on a some calculations/configuration data, give a reasonable approximation of SOC.
JD - Full timer out west
My Adventures & Build
Old 05-22-2018, 02:02 PM   #3
If you are running flooded lead acid (FLA) batteries the most accurate method of measuring SOC is with a temperature compensating hydrometer like this:https://www.amazon.com/OTC-4619-Prof.../dp/B0050SFVHO
The battery monitor is a handy tool but not the best indicator of SOC.
