Old 03-02-2016, 04:33 PM   #1
Chassis: Bluebird
Engine: Cummins
Rated Cap: 73
How to hook up converter
Can I hook up a converter directly into the bus fuse panel to power all the interior and exterior lights ? I'm real nervous about frying my bus. If I disconnect the battery could I hook up to the disconnected terminals? 91 tc2000
toasterman12 is offline   Reply With Quote
Old 03-02-2016, 04:51 PM   #2
opus's Avatar
Chassis: All-American R/E
I would hook it up directly to the battery or a #0 or #2 feed wire.
Old 03-02-2016, 05:34 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Try to park the inverter as close to the battery bank as possible. 4ga wire will work nicely.
Old 03-02-2016, 10:36 PM   #4
roach711's Avatar
Rated Cap: 19
Are you asking about a CONverter (which converts 120v AC into 12v DC) or an INverter (which makes 120v AC from 12v battery voltage)?
dc power
