Old 07-26-2017, 12:32 PM   #1
I can only turn Right
Hello,
I had it pointed out to me after a 3 hour trip down the highway for the first time that even though my front blinker says I am turning Left the rear blinker says I'm turning Right.
My Right blinkers are working appropriately. My Left side signal does not go off at all while the Right rear signal flashes in either instance (turning left or right).
I have fussed in the instrument panel once attempting to replace a declay that fell out. I have taken the control/wiring box apart a few times.
Please assist me in figuring out this issue. What did I do?
5 minutes later - I found my issue. I switched the plugs in my light monitor/indicator.
Pringler is offline   Reply With Quote
Old 09-02-2017, 10:25 PM   #2
Did you make sure the right bulb is in the right socket? Check the simple things first?
Punisher is offline   Reply With Quote
Old 09-03-2017, 12:08 AM   #3
[QUOTE=Pringler;216412
5 minutes later - I found my issue. I switched the plugs in my light monitor/indicator.[/QUOTE]
You gotta love those cheap fixes!
lights, rear, turn signal, wiring mishap
