Old 12-02-2018, 05:53 PM   #1
Year: 2005
Coachwork: International CE200
Engine: VT365
Rated Cap: 26
Identifying the different bulbs / connectors
Hi,
I don't have manuals for my bus (a 2005 International CE), and the $600 it would cost to get them seems a bit excessive
Trying to identify the lights I need at the front. Mail headlamp is a HB5 9007. The other ones I have not seen before. Any help in getting the correct names / numbers would be appreciated! Other then the HB5, I would not mind switching to LED's if that is an option.
The little one actually has it's tabs broken off, anybody know the name of the connector so I can splice in a replacement. Bulb is orange colored and pretty basic. Similar to Christmas light bulbs. How are these called?
The larger light seems to have 3 filaments? The picture below shows the connector itself. Tried to Google the part number for the connector, but that did not take me far
brijn is offline   Reply With Quote
Old 12-02-2018, 09:02 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
The large one is probably a 1157A, A for Amber. There should be a number on the base of the bulb. It has three wires because the base is rubber or plastic. Third wire is ground. Depending on base there aren't really that many bulbs. Small one probably has a number on it too if you can still read it.
