Old 08-03-2018, 10:56 AM   #1
In Search of Power System Diagrams
I'm interested to know how many of you would be willing to provide details of your power systems (particularly solar, but interested in shore, generator, alternator-charged and multi-source systems) to include:
- List of components (including manufacturers and model numbers)
- Wiring specifics (wire gauges, wire types, connection types, etc)
- Location of all components (including wire routing information)
- Diagram of the above
- Pictures
- List of appliances that are powered by your system (including manufacturers and model number)
- Any issues that you have with your particular system configuration
This is to enable the first of many research projects concerning different systems that I want to configure in my future skoolie build.
This is my first thread on this forum...just looking to begin a conversation.
Thanks!!!
climercj is offline   Reply With Quote
Old 08-04-2018, 07:44 AM   #2
golfersmurf57's Avatar
- Pictures
Thanks!!!
Welcome to the forum.
Bus mfg. Is different than other vehicles in that each coach is a unique build. A certain number of x type of bus on" a " type chassis with "b" list of equipment with "c" powertrain. It's not like Alldata with component location. If its new enough, the manufacturers have websites with some info. Some of the used sellers have info too. Older busses you might try the local school bus yards. I'm still hunting for my 92 bluebird but did get some assistance from them. Good hunting!
golfersmurf57 is offline   Reply With Quote
Old 08-04-2018, 08:43 AM   #3
Thanks for your reply golfersmurf! I may not have been clear in my original message. I’m not as concerned with OEM wiring, but instead systems installed during conversion to power lighting and appliances. I’m mulling over the options, requirements, costs, etc.
I’m also interested in diagramming these systems for anyone willing to give me the details and review my work. I know it’s a big ask. It seems to be extremely hard to find this type of information so i’m willing to put the time in for diagramming and confirmation with skoolie owners.
Old 08-04-2018, 10:32 AM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I haven't drawn a diagram for some time and a lot has changed. Here's kind of a list.
Shore power in 50A
Surge protector Progressive Industries EMS-HW50C
Breaker panel. Similar to this one. https://www.ltdrvparts.com/PROGRESSI...0-PD55K100.htm
Xantrex Freedon SW 3000 Only about half of my AC comes from this. Microwave, regular household refrigerator, one of the computers but, not the printers. One of the induction cooktops. My heat is a bit weird and needs 21VDC so that converter also comes from the inverter. Both mini-split AC units are also powered from the inverter.
with this controller System Control Panel
Victron battery minder https://www.victronenergy.com/battery-monitors/bmv-700 with the usb dongle https://www.victronenergy.com/panel-...h-smart-dongle
There are 3 desktop computers and two printers, one is a laser printer. Two induction cooktops and the fridge. There are also two mini-split AC units.
I have a Champion 3000W inverter generator for when I need power and can't use shore power. It isn't wired in I have to run the shore power cord to it when I use it.
Old 08-04-2018, 10:44 AM   #5
How about you doing some research and telling us what you know for certain.
Others put the time and work into this same thing and that is how you learn what you require.
Spoon feeding is not the way to go on this, try some original thought based on research.
If I sound to be blunt, I am.
Old 08-04-2018, 11:11 AM   #6
Thank you somewhereinusa!! I'll take your info and diagram your system out as best I can! I'll touch base with you to confirm accuracy. If you are up for some back and forth to clarify, we'll get a final draft and I'll send it to you to utilize as you wish!!
I feel like you guys are the experts (or you at least have a proof of concept that works for you)! I'm super excited to build my skoolie on the foundations y'all have laid!!
Old 08-04-2018, 11:41 AM   #7
Chassis: AARE
Sure. Inverter gets its power from breaker panel. Inverter has its own breakers for the circuits it powers. I'll try to supply more info but, I'm super busy right now trying to get some last minute stuff done before I leave for a couple of weeks. Also have to mow about 10 acres before I leave.
Old 08-04-2018, 11:52 AM   #8
Awesome!! And absolutely no rush. I'm hoping to perform similar studies on plumbing systems, heating/cooling, and basic layout. In all cases, I plan to create some deliverable that I can give back to the contributor of the info. I'm looking forward to creating partnerships with anyone on here who is willing!!
I assume your "leaving" is a trip in your skoolie! Where are y'all headed?
Old 08-04-2018, 11:56 AM   #9
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
- Pictures
Thanks!!!
I do not normally recommend any of the FB forums, but the skoolie nation one has a recent thread on "helpful diagrams." I thought I took a screen shot of one but I can't find it right now.
2martins is offline   Reply With Quote
Old 08-04-2018, 12:03 PM   #10
Thanks for your advice and recommendation 2martins. I'll check out skoolie nation! Have a great day!!!
diagram, generator, power, propane, solar
