Ok I am finalizing my electrical setup and need some feedback
Main components
3ea 100watt 12VDC solar panels
40a MPPT charge controller
AIMS 2000watt pure sine inverter/charger
3 x 12 volt deep cycle flooded in parallel
125amp/150 amp peak isolator
Battery banks (bus and truck) are about 10-15’ cable length apart from each other.
Solar panel combiner box is mounted 8’ cable length from charge controller.
All other components (charge controller, inverter, fuse panels) are within 2’ or less cable length from the house batteries.
Does this look about right for fuses and breakers?
Is the 2/0 gauge ground wire a good idea to ground the battery banks together with the isolator? Or is the chassis grounds all that’s required?
