Old 02-02-2019, 01:45 PM   #1
geminusprime's Avatar
Chassis: Vista 3600
Engine: DT466E / AT545
Installed new dash, getting engine warnings.
Installed a new dashboard with a few extra gauges, and it works. At least the gauges work that have an appropriate sensor - the trans temp isn't working and the amerage isn't working.
No problem, except that this new dash is also giving me an engine warning.
Codes are:
211 *
EOP
Engine Oil Pressure Signal out of range LOW
155
IAT
Intake Air Temperature Signal out of range HIGH
I made sure the dip switches at the top are in the same position as the old dashboard.
I also reinstalled the old dashboard and it doesn't show engine warning, nor does it output any error codes/beeps.
Bus is a 1997 International Vista 3600. DT466e.
Images are the old panel. New panel is the same, except with the two additional gauges.
geminusprime is offline   Reply With Quote
Old 02-02-2019, 01:55 PM   #2
what are the 2 additional gauges? makes me wonder if something on one of them is wired to a connector on that backboard causing an error
Old 02-02-2019, 01:56 PM   #3
Chassis: Vista 3600
Transmission Temperature Gauge
Amperage Gauge
