Old 02-09-2018, 05:57 AM   #1
Chassis: Saf-T-Liner MVP EF
Engine: Cat 3126b
Rated Cap: 71
Intelligent charge/autostart controllers?
Startimg to plan out my conversion and am hoping there is a programable controller that can charge from solar, use alternator if available, and autostart the generator if the load is greater then x threshold or the battery falls below y percent.
Does such an animal exist or do I need to learn how to build one?
Sent from my SM-G930V using Tapatalk
Godspyro is offline   Reply With Quote
Old 02-14-2018, 10:07 AM   #2
Year: 1973
Coachwork: MCI
Chassis: MC-7
Engine: 8V92 DD 400hp
Rated Cap: 39k
Quick answer: There are several auto-gen start modules for various inverters or stand alone type.
Alternator: you would use a battery isolator to avoid draining your main battery, some alternators have terminals for ACC items, use these.
Otherwise, Xantrax, MagnaSine and other high end model inverers have these capabilities built in, especially the load switching from shore/ alteranator to battery.
Birdarchitect26 is offline   Reply With Quote
Old 02-18-2018, 06:46 PM   #3
Yes, these exist. I think the keyword you want is "automatic transfer switch". Hope that helps.
Professionally converting vehicles and making custom furniture with a combined 14 years of mechanical/electrical engineering experience.
https://www.thunderstruck-studios.com/
ThunderstruckStudios is offline   Reply With Quote
Old 02-19-2018, 02:20 AM   #4
Engine: Cat 3126b
Rated Cap: 71
Birdarchitect26, thanks for pointing me in the right direction, i just need to figure out how customisable they are.
No, that is not the keyword I want.
Old 02-19-2018, 06:27 AM   #5
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
your looking for an inverter /charger. the solar charge controller is another unit. handybobsolar is a good read on rv solar systems.
my build pics
