Old 01-15-2017, 06:52 PM   #21
Originally Posted by clybbert975 View Post
I'm still a little confused on buying salvage? So I can buy a dead inverter then what?
I think he's referencing marine salvage... Not electronics salvage.
Like when they piece out a boat, or RV, or auto.
Same as if I went to auto salvage and bought a radiator, I'd guess.
I'd want to see the DOA return warranty before money changed hands
Old 01-15-2017, 07:58 PM   #22
warewolff's Avatar
So I snagged this Magnum MM1512A brand new for $430 .... it's a 1500w/2100 surge MSW inverter and 70 amp charger. However I am reading it's not 'approved' for RV use. Can anyone educated on the whole neutral vs ground theory tell me why I can't use it?
warewolff is offline   Reply With Quote
Old 01-15-2017, 08:59 PM   #23
dadto5's Avatar
Coachwork: MetroTrans
Chassis: Ford E350
Engine: 7.3 IDI
Rated Cap: 30
Originally Posted by milkmania View Post
Looks like the one in your Hodges link...
inverter
That's it, with a remote.
Leaving June 10, 2017, for 15 weeks. Destination, lower 48, parts of Mexico, all the Candian Provinces that border the USofA. Taking 5 kids and some sandwiches.
Yes, I am crazy.
dadto5 is offline   Reply With Quote
Old 01-15-2017, 09:02 PM   #24
dadto5's Avatar
Chassis: Ford E350
Engine: 7.3 IDI
Rated Cap: 30
Like others have said - it's like buying used parts from a junk yard. Almost any salvage yard you'll buy from will guarantee an item they sell - if they won't don't buy from them.
Yes, I am crazy.
Old 01-16-2017, 07:13 AM   #25
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
I'm using a xantrex that came out of a motor home. I just checked it and the neutral and the ground are bonded both incoming and outgoing. your not supposed to bond your ground but the inverter does it for ya so I don't know. that's the only thing I can think of. magnum is a great inverter, nice find
my build pics
Old 01-16-2017, 07:57 AM   #26
GreyCoyote's Avatar
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
You may be confusing "salvage" with "scrap".
Salvage is generally still useable, albeit with a few scratches, dents, and signs of use. Scrap is (usually non-functional) stuff destined to be recycled, repurposed, etc.
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
GreyCoyote is offline   Reply With Quote
Old 08-23-2018, 01:36 PM   #27
Engine: DT-466
I know I'm resurrecting a dead thread, but I had a question about inverter/chargers. Do I connect the inverter/charger directly to the batteries, or do I need to go through a charge controller like I do for solar? I'm planning on plugging into shore power whenever I get the chance, but just want to make sure I don't overcharge my batteries.
Beeb is offline   Reply With Quote
Old 08-23-2018, 04:15 PM   #28
Your inverter/charger will have three sets of connections:
1 - 120VAC input
2 - 120VAC output
3 - Batteries
The connection to the batteries should be fused at or near the batteries.
An additional charge controller will be needed if you add solar. That will connect to the solar panels and to the battery.
ac electrical, battery, charger, inverter, power
