Old 10-30-2010, 07:59 PM   #1
opus's Avatar
Chassis: All-American R/E
Inverters.......ugh
More things for my aged brain to deal with. Seeing my batteries are in the back. Where do I hook onto? Front panel....battery?? I've done a bit of research of what to look for in an inverter, so I got it picked for now.
Old 10-30-2010, 09:17 PM   #2
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
Re: Inverters.......ugh
Mount your inverter as close to the battery bank as possible, without being in the same compartment. Gasses from the batteries arent good for circuit boards. AC line loss is minimal compared to DC line loss, so leave to long run for the AC side to your breaker panel. Use the absolute largest cables between the batteries and inverter. I found that bulk welder ground cable works well, has a heavy duty insulation and a fine wire braid for flexibility. Only found it colored black, so be sure to mark the positive end at both ends with red tape!
Ob1 is offline   Reply With Quote
Old 10-30-2010, 09:30 PM   #3
opus's Avatar
Ok, I can drill a hole from the batteries up into the back bedroom and mount it on the wall there. Good to know.
Old 10-30-2010, 09:41 PM   #4
opus's Avatar
Its only 1000w. When we park we will use the genset. Moving what little 110v we will have, we will use the inverter.
Old 10-31-2010, 07:56 AM   #5
Originally Posted by Ob1
Mount your inverter as close to the battery bank as possible . . . AC line loss is minimal compared to DC line loss . . . .
To be more precise, higher voltage (120 volts) requires less current per watt and produces less line loss than a lower voltage (12 volts), which requires a higher current per watt. Current flow through a resistance (the wiring) produces heat, which is wasted power.
Raising the voltage decreases current demand and therefore reduces wire heating loss. This is why coaches will often have 24-volt systems. Some inverter systems (including a tiny number on bus conversions) will use a 24-volt or even 48-volt battery bank and a matching inverter with AC-only wiring. These inverters are not department-store finds, though.
If one were to go this more expensive route and still want to add 12-volt DC devices, use a DC-to-DC converter for them. Tapping across the first battery (or first two 6-volt ones) will screw up battery longevity. The cheap and smart way, as stated by others, is to put a 12-volt inverter near the batteries, use heavy wires, keep them short, and keep connections tight and clean.
Old 10-31-2010, 10:02 AM   #6
opus's Avatar
Makes sense to me. I think I can get away with 6' cables.
Old 10-31-2010, 04:23 PM   #7
lapeer20m's Avatar
i totally agree with the above poster that welding cable is best.
use of inverters putterspitt Electrical, Charging and Solar 4 11-25-2010 09:06 PM
Input on inverters. crazycal Conversion General Discussions 6 06-04-2010 07:09 PM
Power inverters and their uses drchefscott Skoolie Conversion Projects 17 04-16-2009 08:46 AM
inverters dwheward Classifieds | Buy, Sell, Swap 2 07-20-2008 04:55 PM
cheap power inverters batchlor BusMan Everything Else | General Skoolie Discussions 2 04-06-2004 05:02 PM
