Old 01-18-2019, 08:07 PM   #1
Is this AGM brand any good?
Looking at different AGM battery brands and sizes.
I'm looking at 500-700Ah total capacity. I've added up my total usage over 24 hours and it's looking like around 161Ah worst case, likely lower.
Does anyone have any experience with this brand of batteries? Looking at two of them in parallel for 500Ah total.
https://www.wholesalesolar.com/99250...8d-agm-battery
If not, any other reasonable price/quality recommendations? I like this style of battery because they aren't tall and should be easier to stash inside the bus. I plan on storing them inside for a more consistent temperature/capacity. I'll likely be in areas with freezing weather, and also hot weather so for me keeping the bank inside seems to make sense for me.
I'll likely put them in a stainless steel enclosure made by the local sheetmetal shop, that's vented to atmosphere, just for an extra safety margin. Is this overkill/not needed with AGM? am I just being paranoid? Real experience appreciated.
kcarsey is offline   Reply With Quote
Old 01-20-2019, 07:01 PM   #2
For NA market, assuming for deep cycling use Odyssey, Lifeline and Northstar.
Old 01-20-2019, 07:56 PM   #3
All good brands. Sadly...Optima, which used to top many peoples lists, has gone in the toilet since they moved production to Mexico. Horrible reviews for the past few years. Bummer. One more good product destroyed by some narrow brained bean counters.
Old 01-21-2019, 05:48 AM   #4
That sucks. I had an optima long ago. It was really great although it did weigh a whole lot.
Roll Your Own Build Thread
Old 01-21-2019, 08:23 AM   #5
I was referring to house batteries for deep cycle. I've heard of Odyssey but always considered them sort of a high end dual purpose or high end starting battery. Sort of a top of the line AGM alternative to a standard auto starting battery. It seems they don't offer real large capacity AGM models. I was hoping to find something 200+ Ah. and do 2-3 in parallel. Less batteries I have, the less batteries I have to worry about staying in balance.
Did a quick search for Northstar, and seems like sort of the same story. Some school buses come with them from the OEM. I suppose i'll do more research.
A lot of the brands for solar seem to have many options. I guess something I should think about is that a lot of the "stationary" solar batteries are ment just for that.. stationary use. Use in a moving, vibrating vehicle would probably be a factor to choose a more "mobile" friendly battery.
Old 01-21-2019, 09:42 AM   #6
No, those are the best, really the only good quality deep cycling AGMs in the N.A. market.
Firefly is specialist, Full River OK but not as good.
And quality + capacity always means heavy with lead. LFP is lighter but 5-7x more.
FLA is **much** better value.
Sure you really need sealed?
Old 01-21-2019, 09:47 AM   #7
I agree.
I would also recommend that, for the bank of that capacity, that you weigh the advantages of a 24 volt or 48 volt battery bank.
Old 01-21-2019, 09:58 AM   #8
There are some pretty sharp folks over on Forums - Solar Panels - Solar Panels Forum who have written some great stickies that are relevant to your project. Here are a few of them:
https://www.solarpaneltalk.com/forum...-size-tutorial
https://www.solarpaneltalk.com/forum...utorial-part-2
https://www.solarpaneltalk.com/forum...s-why-tutorial
https://www.solarpaneltalk.com/forum...battery-design
https://www.solarpaneltalk.com/forum...ry-connections
Old 01-21-2019, 10:05 AM   #9
I don't have the budget for any lithium type battery, although I wish I did.
My inverter size will be 2000 Watts which should put me no more than peak ~166 amps. Figure 250 for a safe margin. I won't have any "hard start" appliances. no a/c units or anything like that. My biggest power user will be a microwave, or my wife's hair dryer. Maybe an angle grinder or other small hand tools if work need to be done on the bus. The hair dryer is the main reason i'm going 2000w instead of 1000w inverter.
I'd like to stay 12v in order to operate fridge, lights, etc and also charge with a 12v alternator. and avoid needing a 24-12 converter. Also if the need arises I could start the bus from the house bank in an emergency.
I should also add that I have the tools/means to have the proper cabling for high current. I used to work with dc power at colo and cell phone sites. I have proper Greenlee crimpers, ends, etc to be able to put it all together with the proper cable.
As far as battery style, i'm not totally locked into AGM. I could probably save quite a bit of money going with FLA. If i'm going to go to all the work to build a proper vented enclosure inside the bus, I might as well save some cash and go FLA, as long as I am able to access the batteries for maintenance.
If I do go FLA, should I look at the same brands? I have done research and there are tons of battery makers and I realize not all are created equal, and two types of "deep cycle" battery may not be built the same. Some are designed as "standby" use and not ment for daily cycling, at least so i've read.
I don't have an exact number on rooftop solar, but i'm going to put as much up there as I can fit. I'd say 1.2kw, but probably more. If I can fit 6 ~300w panels that'd put me at ~1.8kw which would be ideal to have enough charge current for those batteries to be happy. My bank sizing is really just revolving around not going over c/2 or ideally c/4 discharge rate at peak usage, which again will be limited to a hair dryer running for 5 minutes, or a microwave running for 5 minutes, etc. 750Ah / 160 peak amps puts it around c/4.6 which is good.
I've checked out the frequently posted thread here from solarpaneltalk and it has a good bit of info, some of what I have here was gathered from there.
Edit: @pnw_steve just saw your post with the threads over at solarpaneltalk.com
Old 01-21-2019, 10:18 AM   #10
Trojan, Crown, Rolls....
Myself, I will have a similar capacity but a little different configuration. 4 Crown CR370 batteries in series for a24v/370ah battery bank.
I found most everything I need in 24v. Pairs of LED (12v) lights will be wired in series to function on 24v. USB chargers, water pump etc are available in 24v.
I guess that's why we are all here
None of us wants what someone else decides we should have in our rolling home. We want to build to suit what each individual wants.
Good luck.
