Old 04-15-2016, 06:42 PM   #21
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
If it's made by Schneider than it should be good. I have never used one though, I do have a C12 and love it.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 04-15-2016, 06:45 PM   #22
Jolly Roger's Avatar
Engine: Detroit 8.2
Sorry, thanks for the info.
Old 04-15-2016, 07:01 PM   #23
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
I'm confused now..... I think I might have misunderstood your question.
The internet strikes again!
Old 04-20-2016, 06:36 PM   #24
Arvik's Avatar
Year: 97
Chassis: BadMuthaFuka
Rated Cap: All of us
what about this to run fridge while driving between shores?
Honda Generator for Sale! Like New!
or should i go with the batteries and 250 amp alternator route
The road is crazy.
Be safe
Arvik is offline   Reply With Quote
Old 04-20-2016, 07:13 PM   #25
Chassis: Blue Bird
Engine: ISC 8.3
For *just* a refrigerator, continuous load should be easily under 200 watts. When I've measured several of mine they've been maybe 120 watts running. That'd only be about 12 amps off the alternator through an inverter and likely whatever alternator is already on the bus would do fine. Just set up a 500-1000 watt inverter and you're probably good to go. It's when people get into bigger loads like A/C or heating/cooking that a super-duty alternator, generator, etc needs to be brought in.
Old 04-20-2016, 08:22 PM   #26
Robin97396's Avatar
I agree Mr Wagon. Most of these buses already have pretty big alternators in them don't they?
Jester, that generator does look good but it appears to be old, like a garage queen. They've wiped off the dust. It may work fine but something old is going to have problems, especially if you're leaning on it hard sometimes. For that kind of money go with something newer. All these gasoline engines seem to need the carbs gone over every couple years with this ethanol gas.
