Old 04-14-2016, 02:01 PM   #1
jester's Avatar
Chassis: RE200
Engine: 7.3L Navistar T444E
job box for way to split shore power??
what you think skoolies, can i use this to split shore power, then run high quality extension cords to hq power strips strategically placed around rig?
Robot Check
just seems it would be very easy way to dodge making sure grounds are separated in the 120v and 12v systems. thoughts? will this 50amp plug work with the ones in parks?
check out my build pics
http://www.skoolie.net/forums/member...albums833.html
or my random writings... at
www.roadrunnerlogik.blogspot.com
jester is offline   Reply With Quote
Old 04-14-2016, 02:14 PM   #2
roach711's Avatar
Rated Cap: 19
You want your AC distribution box grounded to the bus body to avoid a "hot skin" condition.
The Roach Motel
Old 04-14-2016, 03:45 PM   #3
Chassis: Blue Bird
Engine: ISC 8.3
One of the reviews on that box indicates the inlet connector is CS6364. Parks would have NEMA 14-50 connectors.
As roach711 indicated, there are good reasons to have the ac ground connected to the bus body. I'm not familiar with any good reason for avoiding having the ac ground and the dc negative both connected to the body -- it's generally assumed those connections would both exist, in fact.
Good cords with a few power strips for ac distribution isn't a bad idea. But when I write "good cords" what I have in mind isn't on the shelf at any big box. I'd use the SOOW type cable which has a very thick black rubber insulation (it's about 3/32, almost 1/8 inch). The thinner insulated stuff at home centers, even the "heavy duty" types, may tear open surprisingly easily. The SOOW isn't terrible in price: Home Depot currently offers a 25' roll of 12/3 for $33.21 online. That'd be enough cord to drop an outlet within 8 feet of each end of a 40 foot bus and another one or more in the middle.
Old 04-14-2016, 03:47 PM   #4
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
I'm no electrician, but, I thought the only grounding you did to the body was that of the 12v system. The AC should be ground at the plug site of the SP. How will grounding AC to the bus actually prevent a circuit completion without a "rod in the ground" to transfer it to a true ground??
My build thread - viewtopic.php?f=9&t=467197
Old 04-14-2016, 03:58 PM   #5
Chassis: Blue Bird
Engine: ISC 8.3
Mike Sokol of No Shock Zone has a fairly comprehensive write-up on his web site. He and others have also participated in discussions on grounding topics on skoolie.net here and there. Having things grounded doesn't prevent circuit completion; instead it deliberately provides a (usually less hazardous) path for electricity to flow so that protection devices like ground fault or over-current circuit breakers will turn off the power automatically.
By the way, probably the thing you're thinking of that should be at the plug side of the shore power is the ac ground-neutral bond. That connection should be in just one place, which is normally the main breaker panel at a home or campground.
Old 04-14-2016, 03:58 PM   #6
crazycal's Avatar
I think my exwiff had this condition. If you touched her while she was sleeping, her skin felt like she was 200*. If I could have just ground her, it would have made the nights more comfortable.
I'm hungry!
You Gotta Let Me Fly
Old 04-14-2016, 04:22 PM   #7
Robin97396's Avatar
Apparently your wife doesn't read these threads?
Old 04-14-2016, 04:43 PM   #8
jester's Avatar
Chassis: RE200
LOL so what if she did, that's hilarious. good clean humor.
i thought one of the prongs that go into the shore plug at site was a ground. (universal ground for everything after it?)
really i love the idea of being able to take the box out and use it with generator for other projects. agree with the need for actual HQ cords. just seems like a very easy quick clean way to put ac into the bus.
when you run your 50 amp feed into one of the RV style load centers it wants to be grounded in there and that was what tripped my thought process up was the idea of the 12 and 120 grounded to safe thing(the frame or neg battery terminal)
seemed that keeping all that internal in nice job box was crafty to me. but still need more input. thanks guys n gals
Old 04-14-2016, 04:57 PM   #9
turf's Avatar
when i installed my house 12v system, i chose to not ground it to the frame.
i think you could call it a floating 12vdc -+.
there is a nice safety feature of not mixing the systems, if you incidentally touch the bus with a hot wire from the house, nothing happens.
Turfmobile Build Thread
Old 04-14-2016, 05:04 PM   #10
jester's Avatar
Chassis: RE200
i was thinking the only thing i would use the 12v buss bank for would be the water pump. my rig has 3 batteries so i think the pump will be used intermittently enough to not deplete them to the point of not being able to start. maybe ill put monitor on it so i keep good watch. will upgrade the 12v system to be able to run our fridge is only other 12 v need at later date.
