Old 07-21-2018, 01:29 AM   #1
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Just lost panel lights
I just lost all instrument panel lights and switch lights - poof! (The interior lights that come on when you turn on your parking lights at night.)
Does this sound like a fuse? If so, look for "panel" or something else? And would this be in the driver's elbow fuses or the stairwell/firewall set?
2002 Thomas/Freightliner
Dapplecreek is offline   Reply With Quote
Old 07-21-2018, 06:21 AM   #2
Johnny Mullet's Avatar
Engine: T444E 7.3L
Do you have a pull out type headlight switch? Try turning it because it's also a dimmer switch.
Mullet's Thunder Bus Build
Old 07-21-2018, 08:23 AM   #3
No, it's a three-position rocker (off, running lights, headlights+runninglights).
I had the running lights on, then hit the 'increase idle' rocker, and all of the panel lights went out.
Old 07-21-2018, 09:47 AM   #4
Very hard to pinpoint your problem without removing the switch or gaining access to see what is going on. Could be condensation that tripped it or bad grounds.
Check connections for power with a meter
Old 07-21-2018, 10:33 AM   #5
For many years the tail lamps and instrument panel lights were on the same fuse--sort of a heads up for safety if your tail lights were out at night. One more thing to check out. Jack
Old 07-21-2018, 09:34 PM   #6
Tail lights are fine; instrument illumination is out. Can't find a conveniently-labeled fuse, though I did find a "panel lamp relay". Will put a meter on that tomorrow.
Old 08-03-2018, 03:05 PM   #7
golfersmurf57's Avatar
One switch light usually local to the switch all lights indicates fuse relay or switch failure. Also dimmers have a nasty habit of failing even the ones in the pull types.
golfersmurf57 is offline   Reply With Quote
Old 08-03-2018, 04:26 PM   #8
We found a "Panel lights" relay in a second fuse box under the dash. We swapped it with its brother and got the lights back. Thanks!
