Old 08-18-2017, 09:07 PM   #1
Year: 1994
Load center type
For a 120v system with 50amp plug in, what type of load center are you using? Main lug or Breaker? The physical size of the main lug style I found fits best in my basement, but not positive I should trust every rv park to provide protected circuits.
I may have spaces to backfeed 50amp service through a breaker if necessary.
For the record, I will have an electrician bless off before I connect to live.
Thanks in Advance!
J
Jameson is offline   Reply With Quote
Old 08-19-2017, 10:32 AM   #2
Great plan!!
I would go with a load center with a main breaker. I would have to dig out the code book to verify but I am pretty sure that NEC requires it.
Even if it doesn't I would not trust the RV park pedestal to protect my bus.
Just my $0.02
Old 08-19-2017, 02:35 PM   #3
Year: 1994
Good advice. Was looking at RV specific load centers that combine AC and DC in one unit, and they were protected with a main.
I know people on here have used main lugs though and haven't heard of problems yet. Think I will spend a few more dollars and go with a main breaker.
J
Old 08-27-2017, 12:01 PM   #4
Defjr333's Avatar
Chassis: Step Van
Engine: Prefer Diesel
Rated Cap: 14'-16' Step Van
Since I didnt need a converter for dc side( using an inverter/ charger with built in xfer switch) I decided to go with this unit. They do offer larger units if needed. It has spot for Main breaker(input from shore/ genny) and 4 breaker locations for your appliances. On the DC side it has 12 spots for your DC items. For $60 thought it to be a steal...
PD5000 30 Amp AC/DC Power Control Panel
Doug
Defjr333 is offline   Reply With Quote
